front diff weight?
Old Dec 30, 2004 | 12:43 AM
krazykoncepts's Avatar
front diff mount weight?
I am getting my front mount of the rear diff redone in poly. I was wondering what the front diff weight does? I am talking about the rectangle box bolted on to the front of the diff mount bracket.
Old Dec 30, 2004 | 12:46 AM
RotaryEvolution's Avatar
Sharp Claws
huh?
by rectangle box do you mean the engine? lol!
there is no front differential in an FC.
Old Dec 30, 2004 | 12:59 AM
Kenteth's Avatar
Like Ghandi with a gun
there are two rectangle boxes, one is a vibration absorber, the other is the actual mount bushing. Changing the vibration absorber to poly won't do anything, except cause more vibrations as the stock one has a metal interior and pretty heavy IIRC. changing the dif mount to poly may cause more vibrations than the stocker, as its poly. I'd say get a new stocker, since it will probably cost less than a fab'd poly.
Old Dec 30, 2004 | 01:08 AM
thanks kenteth. i was talking about the one for vibrations i guess, and i will leave that one stock. I think it would still be better to make the other box out of poly since it will stiffen things up.
as for karack.......ummm? ok lol
Old Dec 30, 2004 | 01:12 AM
Sharp Claws
your post is a little hard to read, you mean front of the diff(rear).
SonicRaT's Avatar
Super Raterhater
He's talking about parts of the mount, not the differential itself. DSM people generally refer to a front (or center) diff on AWD cars and etc, so people get confused.
Old Dec 30, 2004 | 01:14 AM
i edited the post a little to make it easier to read. If your not familar with the diff and the bracket it wont make sense to you though.
Also were can i buy a poly front mount bracket for my rear diff? I want to see prices
Old Dec 30, 2004 | 01:15 AM
bcool's Avatar
Rest In Peace Dave
I got lazy and welded mine solid
Old Dec 30, 2004 | 02:16 AM
Sharp Claws
never seen them in poly but Mazdatrix has a sport mount with a stiffer rubber in the mount:
http://mazdatrix.com/g8.htm
the metal block is to absorb the driveline vibrations, which if you use poly it is counterproductive anyways. the stiffer bushings will transmit more vibrations through the body than the stock bushings but they will be able to handle more torque which i'm sure you don't care about anyways so i wouldn't worry about the metal vibration damper.
Old Dec 30, 2004 | 09:37 AM
owen is fat's Avatar
you dont need to say rear diff, as there is only one diff in the RX7.
you could run a solid diff mount, like I did, the increase in perceptable vibration is minimal.
