help please trying to get heat shield off to fix leak
Old Dec 29, 2004 | 12:52 PM
skatingsamurai's Avatar
Unhappy help please trying to get heat shield off to fix leak
i was just wondering what some good methods for taking off the heat shield of the turbo would be. i did a search but i diddnt find any ways they used for accually taking it off. should i use some sort of prying? or maybe i should cut it. let me know please
please dont be SO alarmed...i will be making another heat shield. is 12gauge sheet aluminum ok?
Old Dec 29, 2004 | 01:00 PM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
if i remember correctly it was a PITA to get mine off. i had to remove a bunch of stuff and i had to pry it a few times to semi bend it in the shape that i needed to get it to clear everything. all i remember is putting it back in was very easy .. i would love to help you out more but my engine isnt here. but i wouldnt cut it . but there are like 3-4 10 mm bolts that hold it on . and i used a screw driver (flat) to gently pry the 2 sides away from each other. then i had to get under the car and take off the other bolts. although the bottom one was so rusted it snapped with no real pressure. then i think i bent it up a little, and took off the DP . i think that was what i did. and with the DP gone you should have enough room to drop it out the bottom
Old Dec 29, 2004 | 02:19 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
PITA is right. I have to destroy mine to get it off.
Old Dec 29, 2004 | 02:27 PM
oh yay. pry bar time it is then....
Old Dec 29, 2004 | 02:37 PM
Cybaster's Avatar
I think I'm addicted
yeah, i took off most everything, and use brute force to pull it off..... its a tight fit...
Aaron Cake's Avatar
Engine, Not Motor
Rip it off. But when you make your new shield, don't use aluminium. Use stainless steel. Aluminium won't last very long.
Old Dec 29, 2004 | 03:47 PM
i have a quick question.......do i have to worry about that hard line that has coolent in it?
it seems to be rubbing up against the shield as i am tearing it out. anything thoughts?
also can i wrap the turbo in aluminum sheet metal ? or will it melt?
Old Dec 29, 2004 | 03:50 PM
I dont think you can put enough force pulling out the shield to damage the coolant line as it is pretty thick and sturdy. I think aluminum may retain too much heat and warp after time and you'll probably get rattling too.
Old Dec 29, 2004 | 03:57 PM
thanks a bunch
Old Dec 29, 2004 | 03:59 PM
well seeings *** how i cant really find some other kinda od metal right now.... can i use the aluminum to protect things other than the turbo.... like put it around the intake... hoses so on and so forth?
Old Dec 29, 2004 | 04:02 PM
I've been running without the stock heatshield for probably about a year and no bad effects except the engine bay feels hotter but all my wiring is ok, but that might be because I rewrapped the whole thing.
Old Dec 29, 2004 | 05:09 PM
welli got everything off and i tightend 3 of the 4 bolts on the exhaust manifold.....how in the hell am i suppost to get to the upper right ( when your looking at the engine from the right)bolt
its a pain in the ***
Old Dec 29, 2004 | 05:10 PM
i just kinda stuck it back on there
i dont think itll fall out, lol
connerfd3s
Sep 19, 2015 05:58 PM
t-von
Sep 10, 2015 01:56 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
gabescanlon
Sep 5, 2015 12:04 AM
