why does my horn go beep?
Old Dec 27, 2004 | 05:42 PM
koukifc3s's Avatar
Clogged cat
Hi,
my horn goes off by itself and I have no idea why.
At first I thought it was because of my aftermarket steering wheel horn so I took it out but it doesnt seem to be the case
I think it is because of my cheap steering wheel hub I got off ebay. I think it is making a contact somewhere since it only happens when I turn.
What do you guys think? I should buy a new hub?
Old Dec 27, 2004 | 05:58 PM
Icemark's Avatar
pictures are kinda blurry, but I don't even see the horn pick up on your aftermarket adapter.
is there one???
the horn contact in the top picture looks very worn
Parastie's Avatar
Mountain Rotary Mod
Is the hub metal? If so, just put a layer of tape or something nonconductive on it and see if that helps.
Old Dec 27, 2004 | 06:48 PM
koukifc3s's Avatar
Clogged cat
is this the horn contact? Right now that switch is pushed down and stuck.
I dont think the hub has a horn pick up, it'd made of metal tho
thank you!
Old Dec 27, 2004 | 08:00 PM
Icemark's Avatar
thank you!
Yes that is the pick up. On a stock wheel, that slides against the back of the steering wheel on a contact, and when you puch the horn button it grounds the contact (which is touching the pickup and sends the ground to the horn relay in the CPU).
If the pick up gets grounded the horn will honk.
Old Dec 27, 2004 | 08:35 PM
Fritz_X's Avatar
In lamens terms, get it fixed or stop going over potholes!!
--Fritz
beep beep beep
Old Dec 27, 2004 | 08:41 PM
vincentwashere's Avatar
Bmw 325is & RX7
hey that same thing happened to me. it was because the contact screw fell off and it just would contact and honk the horn whenever it felt like it
FC3S Timmy
16
Oct 3, 2015 01:08 AM
