need help on installing the toe elimenator
Old Dec 10, 2001 | 09:03 PM
yamatokh's Avatar
Hi everyone,
I just order a pair of rear toe elimenator from Mazda Competition. The problem is that it didn't come with installing instruction.
If someone has install it, please share your experience and tell me exactly where to put it. Pictures will be great. Thanks very much in advanced.
Old Dec 10, 2001 | 09:39 PM
Node's Avatar
I saw your post and thought they had the instructions at Racing Beat (because they sell them) which htey didn't. So I sorta gave up, but then I was looking through Mazdatrix's wonderful site trying to find the difference between their DOT approved Stainless Steel brake lines and non-DOT approved SS brake lines. No luck. But I did spot this. Good luck!!
http://www.mazdatrix.com/faq/rrsteer.htm
Old Dec 10, 2001 | 09:56 PM
cymfc3s's Avatar
I Raise Chickens
It requires removing the rear axle/hub assembly. You also will need a hydraulic press to remove the stock busing and install the new delrin ones. Its a big pain. I did it on it mine, but i had everything apart. I had a machine shop do the bushings. Its a big job.
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
