For synthetic oil users only
Old Dec 10, 2001 | 08:55 PM
I have 58,000 miles and have always used castrol 10w 30 but after learning more about motor oil have decided to switch to synthetic. Will my engine possibly leak, loose compression, or have any other ill effects due to this switch.
Old Dec 10, 2001 | 10:02 PM
billyrohm's Avatar
Man who sold his 7
Dude If I were you I would run some semi-synthetic. Conventional oil has some good stuff about it too.
If you dont have any leaks now then you shouldnt leak with the synthetic.
I run Torco T-4R semi synthetic. Works well.
Old Dec 10, 2001 | 10:57 PM
I personally wouldnt switch with that many miles on your car after using regular oil the whole time. I've heard that if you switch to syn. after using reg. with many mi (ie:58,000) that the syn. will actually clean everything out around your seals leaving them more prone to breakdown. Again this is just something i've heard.....no real proof.
Old Dec 11, 2001 | 01:26 PM
KZ1's Avatar
KZ1
The owner's manual specifically says not to use synthetic, I would be careful.
Old Dec 11, 2001 | 02:37 PM
JspecFD's Avatar
Re: For synthetic oil users only
As long as your car is running fine now, it'll only run better with a good synthetic. Semi-synthetics are a waste(can you name one advantage billy over a good synthetic?) and mitigate some of the synthetics inherent advantages over conventional oil.
At least everyone agrees to run synthetics in the tranny and diff.
Old Dec 11, 2001 | 05:04 PM
wickedrx7's Avatar
no synthetics
This has been a huge debate for awhile. There was a news release a few years ago by Mazda saying not to run synthetics in rotories. The main reason is because a rotory motor injects oil into the combustion chamber to lubricate the apex seals. Synthetic oil dosn't burn as clean as mineral oil and it will leave depostits in your motor and it will clog you cats. I would just run a high quaility mineral oil 20w 50.
Old Dec 11, 2001 | 06:36 PM
Zoomspeed's Avatar
I was told the same thing by my shop teacher a couple years ago. He explained that after using mineral for so long you get build up in spots; sometimes this build up actually plugs up places where oil would leak. Then when you run the synth it cleans it out and you have an oil leak.
Makes sense doesn't it?
Old Dec 11, 2001 | 07:52 PM
RTS3GEN's Avatar
The Man
Ah Hah, the age old "synthetic in a rotary" debate. Well, from lots of racing experience both personally and vicariously thru Pettit Racing, Rotary Performance and many others synthetics work just fine, even after 80K miles on my previous motor and a tear down after ping-Clean housings, rotors and bearings, virtually no evident wear at all. Only evidence of failure was two rear rotor apex seals fractured. Yes, properly maintained conventional oil will protect almost as well, the mineral (conventional) oils do not have the shear strength to withstand high temps, they just lose their viscosity too easily and can lead to less protection under these circumstances, especially when turbo(s) is/are involved. Just for added clarification also TWO manufacturers have the technology to make a 100% synthetic oil: Mobil 1 and Amsoil. Although other manufacturers claim synthetic on the container, they aren't true 100% synthetic, and if they are(Mobil 1 has been considering selling rights to some of its technology to other oil producers) they haven't mastered the art of the 100% synthetic race tested motor oil!
Just my 2 cents worth.
Old Dec 11, 2001 | 08:23 PM
juliof's Avatar
I dont think its worth changing over to synthetic, you still have to replace youre oil every 3 K or less.And at $4 or more a quart it adds up, vs $1.10 for GTX the only real plus with synthetic is that it can withstand higher temps that youre motor will never see unless you race.It will reduce oil temps but if you have a upgraded cooling system youre water and oil temps will be lower any ways.And its been proven that synthetic dosent reduce wear any better than mineral based if replaced at the same time.
Old Dec 11, 2001 | 10:32 PM
Pressurized's Avatar
Why not just disengage the OMP and use premix instead, then you can run Synthetic if you want because it will no longer be injected into the combustion chamber?
Old Dec 11, 2001 | 11:22 PM
Tim Benton's Avatar
FD title holder since 94
dear god no
I'm not posting about the oil question, but just wanted to say, I HOPE TO GOD THAT PICTURE IS A MISTAKE...AND SOMEONE DIDN'T PAINT THEIR CAR MARY KAY PINK!!!!!
Tim Benton
Old Dec 11, 2001 | 11:49 PM
DeNguyen's Avatar
Re: dear god no
Tim Benton
ditto...
thats gotta be the ugliest FD ive ever seen
Old Dec 12, 2001 | 07:49 AM
Hahaha....no, the car really isn't pink. I know that guy. His car sat at the shop for a long while and the sun faded it. Then someone was kind enough to photoshop that pic for him as an inside joke.
Love that picture, Tommy.
Old Dec 12, 2001 | 09:28 AM
pp13bnos's Avatar
Pineapple Racer
I don't know if someone botherd to say this or not, but when running my pp, i used 15-50 mobil 1. What i noticed was after a hard run, the oil tempatures would not go up as high, and would come back down faster. when i had it torn down, (because a nut and lock washer went through the rear rotor.) the bearings looked mint. This was with about 15k miles with 50-150shots of nos sometimes. CJ
Old Dec 12, 2001 | 11:04 AM
LOL...thanks Steve. I'll post a new pic of my car in my sig after it gets painted but until then......i'm gonna leave the Mary Kay FD right where it is
Old Dec 12, 2001 | 10:07 PM
RTS3GEN's Avatar
The Man
"the only real plus with synthetic is that it can withstand higher temps that youre motor will never see unless you race."
posted by juliof:
Um, how many here have an FD and haven't raced it at some point? Drag strip? ever do a couple dyno pulls? Ever raced a Chevy Camaro.
That's the idea, and trust me from personal track experience, synthetic oils stay cooler than conventionals, their ability to dissipate heat is far greater than any conventional. Sustained boost on a full imsa GT road race will get oil temps into the 220-230 degree range, and you'd better hope that the oil is holding up. Wouldn't it be nice to know that your oil has the ability to withstand these conditions, just think of the protection you'll get under "normal" street conditions(be it racing that camaro or running on the dyno). Case closed
Art
Old Dec 13, 2001 | 01:25 AM
juliof's Avatar
PROOF www.scuderiaciriani.com/rx7/oil.html
Old Dec 13, 2001 | 05:04 AM
maxcooper's Avatar
WWFSMD
I was running Royal Purple blend for a while and it seemed to work well in that it kept my oil pressure up higher at idle when the car was hot than the Havline that I was running before did. But it seemed to get "dirty" at about the same rate.
I recently switched to Royal Purple Racing oil (full synthetic) and it seems to stay cleaner much longer.
I am not speculating why this is true, just relaying my observational experience.
Also, my 88 T2 Owner's Manual also said not to use synthetic oil, so the recommendation existed before the third gen was produced. I ignored it then, too.
-Max
Old Dec 13, 2001 | 09:58 AM
BizarroTerl's Avatar
I use Redline for one reason - coking in the turbos. I figure the higher temp capability gives me a little more protection.
