Any downside to using 2 tralling coil packs instead of 1 of each?
Old Dec 24, 2004 | 11:21 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Ok, i am going to be doing my engine swap and wiring in a wolfv4 starting sunday. On pg 44 of the instalation manual for the wolf it talks about multi-coil ignitions for rotary engines and there wiring. There is a side note mentioning that
"We (wolf) strongly recommend using one coil pack per sparkplug in all rotary applications. This is because of the high-energy requirement placed on ignition systems used on rotary engines. Dual Output coils, although having a high secondary voltage, are biased to one of their outputs, causing one output to have weaker spark than the other."
Just looking at the wiring diagram for 4 individual coil packs and the wiring on the coil's makes me belive that this would be an extra 2 min of wiring, so that I am not worried about
I was wondering though if there is a downside to using 2 trailing coil packs? Are they weaker than the leading coil pack etc?
-Jacob
Old Dec 24, 2004 | 02:39 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Interesting. Wouldnt an MSD box help fix the problem?
Old Dec 24, 2004 | 03:31 PM
Kingofl337's Avatar
Letting the Smoke Out!
Talking
Buy a 4 pack of MSD Blaster Coils
Old Dec 24, 2004 | 04:06 PM
wpgrexx's Avatar
you should check out the electromotive coil setup. very nice 4 coils. Grass roots motorsports used it in their rotary spitfire
Old Dec 24, 2004 | 05:09 PM
bdrx-7's Avatar
i would like 2 no 2 wouldn't it b better 2 get something like a MSD ign cuz i can get one 4 me for dirt cheap
Old Dec 25, 2004 | 09:34 PM
I know it would be cheap to buy aftermarket coils, but i have a few sets of good coils, nobody has ever attempted this?
-Jacob
Old Dec 26, 2004 | 04:32 PM
NZConvertible's Avatar
I'm a boost creep...
We already have one coil/ignitor per trailing spark plug, so I presume you mean replacing the leading coil with two seperate ones (thread title says trailing). I've seen many cars make a lot of power on the stock coils without probs, so unless you're aiming for really big power I wouldn't be too concerned.
Old Dec 26, 2004 | 06:17 PM
White_FC's Avatar
I guess it really depends on wether or not the Wolf V4 is setup for using two leading ignitors or one? Or has it got just one 'trigger' output that you can daisy chain external ignitors off? .. sorry i don't know squat about the Wolf ECU's..
If you have the option, you might aswell run dual leading ignitors/coils.. IMHO.
(having said that i'm running the stock leading coil.. )
Old Dec 27, 2004 | 05:26 AM
RETed's Avatar
1) I dunno how you're going to adapt the "trailing pack" to the leadings?
Do you realize that the trailing coil pack uses one signal channel and one toggle channel.
Does the Wolf3D has some kinda control to handle running the toggle on the leadings?
2) Running single coils on the leadings does not guarantee you retain the wastespark "far trailing" spark that cleans up the combustion chamber.
Does the Wolf3D explicitly state you keep this extra spark?
-Ted
Old Dec 29, 2004 | 08:02 AM
The online version of the manual i am quoting this from is here
http://wolfems.com/products/enginema...nstallshortcut
Pg's 44-45 (ill upload screenshots of the diagrams also)
From what i understand of wolf's wiring dagram, there is no 'toggle channel' output from wolf to either set of coils. Wolf simply runs one ING output to each coil (one to each trailing ignotor, and 1 to the leading pack)
Im pretty sure judging by the wiring diagram that i would retain the wastespark running 2 seperate coils because the ING output that goes the the leading coil is simply split and run to both seperate leading coils
Isnt the leading coil the duel output single coil? I only say that because the trailing coil is 2 seperate coils and the leading is one large unit. Am I wrong?
I have a feeling that there is a bunch of confusion as to what i am trying to so
So the first attachment is what i would wire if i used the stock coil/ignitor configuration with the wolf
The second attachment is what I am wondering if i can do using 2 <b>TRAILING</b> coil packs. Again i say trailing because from looking at them visualy it looks as if the trailing is 2 seperate coil's, and the leading is one single coil with output's to both leading plug's
-Jacob
Attached Thumbnails Any downside to using 2 tralling coil packs instead of 1 of each?-upload1.jpg   Any downside to using 2 tralling coil packs instead of 1 of each?-upload2.jpg
Old Dec 29, 2004 | 12:20 PM
White_FC's Avatar
Ok basically you can´t use the trailing ´pack´ at all....
You could use the coils, but you need after market ignitors, probably bosch ones.
for the leading it would appear that you COULD use the stock ignitor/coil combo.
OR you could divide the signal, like i thought earlier, to power two seperate ignitors and two separate coils.
but for the trailing, since the wolf has two outputs, one for each coil you cannot use the stock trailing ignitor. You need two seperate ones.
Old Dec 29, 2004 | 03:00 PM
RETed's Avatar
If this is true, you can't use the stock trailing toggle ignition coil pack at all?
That is correct.
It's called a "dual tower" coil, so it's a single input that fires off two spark plugs at the same time.
-Ted
Old Dec 29, 2004 | 04:21 PM
Kenteth's Avatar
Like Ghandi with a gun
Can you guys just quickly correct me if I'm wrong, Leadings fire simulatnoisouly, and the trailing fire independantly. And... why?
Old Dec 29, 2004 | 04:25 PM
RETed's Avatar
Try search for those rotary engine simulations that show the ignition firing correctly.
That wastespark'd leading fires as a "far trailing", so each rotor face actually sees three sparks on combustion!
You can't do this with the trailings; if you did, the wastespark'd trailing will fire too early in the other rotor.
-Ted
Old Dec 29, 2004 | 08:55 PM
Im not sure, I am using the wiring diagram from this post
https://www.rx7club.com/showpost.php...54&postcount=1
There are 2 wires to the trailing pack, im not thamliar with what these actualy go to 100% though so i cannot say 'its right'
Coils
IGN1 - RED Trailing Coil 1
IGN2 - YELLOW Leading Coil (1 & 2)
IGN3 - GREY Trailing Coil 2
Wolf Color ---------------- Mazda Color
RED-------------- RED Trailing Coil
GREY ----------- WHITE Trailing Coil
YELLOW ---------- RED Leading Coil
As for the ignitors, this is the first i have hurd of needing an aftermarket ignitor for the trailing coil pack, I guess ill call around to find out about this. It doesnt mention that the wolf cannot use the pack anywhere in the manual. With the rotary specific diagram it gives with the leading and trailing packs, If it wasnt compadiable you would think they would mention something
-Jacob
Old Dec 29, 2004 | 09:03 PM
Kenteth's Avatar
-Ted
and thereby trying to push the rotor the opp direction/? makes sense.
Old Dec 29, 2004 | 09:52 PM
White_FC's Avatar
CrackHeadMel, just call your wolf dealer that your bought the ECU from and ask them if your ECU is setup to fire the stock trailing ignitor/coil or two aftermarket ignitors/coils.
Old Dec 29, 2004 | 09:58 PM
White_FC's Avatar
Okie with about 2secs of searching, "The only problem i can see is the ignitor, but thats an easy fix with the bosch 2 channel one. "
that was from 'Fatty_FC3S' in https://www.rx7club.com/forum/showthread.php?p=3359183 that thread.
Old Dec 30, 2004 | 04:52 AM
RETed's Avatar
Bingo...
-Ted
Old Dec 30, 2004 | 07:52 AM
Is that as specific as i need to be when i go to a parts counter? a bosch 2 channel ignitor?
-Jacob
Old Dec 30, 2004 | 08:09 AM
NM, i found the wiring and the part number for the reccomended bosch ignitor
Its here on page 5
http://wolfems.com//freestyler/gui/f...20Tech%205.PDF
Old Dec 30, 2004 | 06:48 PM
totallimmortal's Avatar
Is that thing Turbo?
this thread makes my head hurt
Old Dec 31, 2004 | 07:23 AM
Hey mine too
I wasnt able to find the ignitor. I went to VW and they had one similar however it had 2 plug's and 4 more spade connectors than the one reccomended. they also wanted $327. After that I went to the only auto parts store in my area that anybody knew that sold bosch ignitors. They were able to bring up listing for the reccomended bosch 200 however it was a special order and he couldnt get me a time frame, or a price untill it came in. He did however tell me it was a porsche ignitor and a porsche dealer might have one instock (i can only imagin how much that is going to be)
Being that I coulnt find the reccomended ignitor at a cost i can afford, can i run 2 single channel ignitors?
-Jacob
Old Dec 31, 2004 | 11:05 AM
Net Seven's Avatar
Yes this is correct, you cant use the stock trailing ignitor. I called up Chris (wolfems dealer) and he told me to just disconnect mine for now and run just the leading, til I get an ignitor for my trailing.
I took the CAS out and was spinning it by hand and watching the sparks, the ones comming out of the leading coil were very strong and looked good. I had the tailing wired up same way as you would a haltech, but the spark was very very weak and wasnt as often as the leading spark.
Anyone see anything horribly bad about not running the trailing spark for now, while I get myself an ignitor? Chris told me its fine and they used to run them that way back in the day all the time.
Old Dec 31, 2004 | 06:28 PM
Could that be why i was getting an error count while trying to start my car today?
-Jacob
