upgrading stock engine
Old Dec 23, 2004 | 08:31 PM
13bturbo2's Avatar
hey guys i would like to know what upgrades would be good now that i have my engine out of the bay. its an S4 Turbo II 13BT and i would like to upgrade it for street use i mean nothing too extreme just for simple daily driving and ocassional track use.
Old Dec 23, 2004 | 09:28 PM
therotaryrocket's Avatar
PIMP
port your wastegate, port match the manifold to the turbo inlet, if you rebuild then street port it and use fd corner seals and springs and oil pressure regulator, remove emmissions. I don't know just some ideas. good luck
Old Dec 23, 2004 | 09:30 PM
scheistermeister's Avatar
Throbbing Member
not really an upgrade, but you might want to check the condition of all your brake and fuel lines.
Old Dec 23, 2004 | 09:32 PM
RETed's Avatar
1) How much power you want to make?
2) How much money you willing to spend?
-Ted
Old Dec 23, 2004 | 09:51 PM
13bturbo2's Avatar
i'm willing to spend at least 2k on it. now the brake lines are ss and the fuel pump and lines will proly be in that 2k investment. as for rotaryrocket's reply thanks, i mean i would do all of that if there was a shop in my country that actually knows what a rotary is and how to care for it. i know how to care for it because my dad used to own 2 rotaries R100 and a SA22 12AT. i would like to make around 220 - 230 at the wheels, or more if possible with that investment...it has to be streetable nothing extreme.
Old Dec 23, 2004 | 10:11 PM
Throbbing Member
i was talking about the hard brake lines. when i changed out the rubber ones for ss i found out that they were very degrated.
Old Dec 23, 2004 | 10:46 PM
13bturbo2's Avatar
i might have to check that then.
so anything?
Old Dec 24, 2004 | 04:37 PM
13bturbo2's Avatar
bump...ok so far i've got the exhaust system (single n1 cat) and a KN cone air intake...i dunno if i should get the dp though. i was gonna start with the simple stuff first like a Greddy Auto Timer and some gauges. cause i have no idea if the dp will get me into the Fuel cut zone, proly will. so then after that i would buy the dp and the FCD. after that i'm gonna get the Walbro 255 and some 720cc secondaries. then to top it off a S-AFC. how much would i be making with all of that in place?
Old Dec 24, 2004 | 05:37 PM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
lightweight fly wheel , TB mod, paint some stuff and make it look pretty, plugs, wires, new power and ground wires
Old Dec 24, 2004 | 05:44 PM
13bturbo2's Avatar
tb mod on the way as well as the tid mod. light weight flywheel should be an ACT XACT, i'll proly get it for my bday, car's gonna get a new paint job in january, factory white *hehehe there's only one other fc in panama thats turbo and its black so i just want to be its opposite.* plugs will be denso iridiums and the plugs will be either magnecor or msd...now about the ground wires, hows that new HKS super ground system?
Old Dec 24, 2004 | 05:46 PM
rx7whore's Avatar
flywheel all the way....makes the car rev sooo much faster
Old Dec 24, 2004 | 11:05 PM
PIMP
have you seen the r-tek 1.7 ecu upgrade? It modifies the ecu and includes the fcd, early secondary operation, and some other stuff not on mind. yea my s4 t2 revs so slow compared to my friends 87 n/a. whats the tid mod? i'm about to search the tid mod.
Clacor
Aug 14, 2015 09:17 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
