RB turbo II System smokes
Old Dec 21, 2004 | 01:05 PM
ballz7's Avatar
i just started my 87 TII and it was smoking realy bad is that the pipes burning out. becuz whan i looked back i could not see thru the smoke it was white and very thick. any IDEAS?
Old Dec 21, 2004 | 02:00 PM
Scalliwag's Avatar
WingmaN
What is the story behind the car? Rebuild, sitting a long time? It could be oil control rings or oil getting into the turbo or ?
Old Dec 21, 2004 | 03:22 PM
speedturn's Avatar
Check your antifreeze coolant level - see if it is using coolant
Old Dec 21, 2004 | 04:52 PM
Scalliwag's Avatar
WingmaN
Ooops, he said white didn't he My bad. Definately coolant. You may also see water dripping out the exhaust if it is coming out that thick.
Old Dec 21, 2004 | 06:32 PM
RETed's Avatar
Could also be oil...
Most likely it's oil.
Can you smell the smoke?
Burning oil burns your eyes and nose.
Burning coolant will smell sweet and not burn your eyes and nose.
-Ted
Old Dec 21, 2004 | 06:44 PM
Scalliwag's Avatar
WingmaN
Most the time they smoke it is oil but if it is white as he says then it's water. But I guess one man's gray is another man's white
Old Dec 22, 2004 | 03:30 AM
RETed's Avatar
I "blew" my motor when my oil pressure regulator fell out of the front cover.
Yes, I torqued it via torque spec in the Mazda FSM with a Snap-On torque wrench.
The lower oil pressure burned all the oil control o-rings.
It was burning tons of oil.
Trust me, the smoke was ghost white.
It was billowing like a James Bond smoke screen.
It was like ATF, but thicker like clouds.
It burned your eyes - this was the only way I could tell it was oil.
-Ted
Th0m4s
Feb 26, 2019 02:04 AM
86glxNA
Aug 22, 2015 08:54 PM
pzr2
Aug 15, 2015 08:29 PM
