any FC´s(or FD) with Blowzilla yet??
Old Dec 9, 2004 | 05:44 PM
Faster Is Faster's Avatar
just liked to know does any FC owner have this Blowzilla? Is it worth of to consider?If not how about FD owners? If I remember correctly there was someone with the blowzilla but wasn´t tuned at the time so I´d like to know the results? How do they spool up and at what rpm? what kind of rwhp should be expected with a street ported engine @~15 psi?
Thanks
Old Dec 9, 2004 | 10:05 PM
Deathstar's Avatar
Yes, I fit
i'm assuming blowzilla is a turbo right? I've never heard of it. Is it a code name for a t something?
eric
Old Dec 9, 2004 | 10:07 PM
Crusader_9x's Avatar
www.cheapturbo.com
It is a t4 turbine witha gt35r compressor non ball berring i think.
Old Dec 9, 2004 | 10:14 PM
nyt's Avatar
nyt
I'm running a T61 with a .96 undivided p trim back.
the t61 uses the gt35r compressor wheel with a to4s cover.
I see 20psi at 4500rpm on a stock motor with the hks cast undivided manifold. i love this turbo. im making over 450rwhp on pump gas with it on a stock port s5 motor
Old Dec 9, 2004 | 10:15 PM
fc3s-gxl's Avatar
i tought you meant the blowzilla wastegate
Old Dec 9, 2004 | 11:08 PM
CCarlisi's Avatar
Rebreaking things
I have one with a large street port. I ran into a transmission/clutch problem so I haven't had a chance to finish tuning it. It has usable boost response in 4th or 5th gear at 3000rpms+. It will spool up around 2500, but you have to be patient. It flows 61lbs/min and is a bit more efficient than a T04s. Therefore, with proper tuning, it should make a little over 400rwhp at 15 psi. I have also driven a car with a GT35R (ball bearing) and a street port. I didn't notice a difference in the spool up. However, the BB 35R had a 1.06 undivded exhaust while mine has a 1.00 divided, so it's not a perfect comparison.
Old Dec 10, 2004 | 03:12 AM
Marcel Burkett's Avatar
How would two of those work on a 13B ?
Old Dec 11, 2004 | 11:26 AM
elnr's Avatar
Ive got this turbo on my Fd...with cast hks manifold...had it tuned on the road but not dynoed yet.....road tuned tuner said it was quite a bit quicker than his gt35r kit.....so that should give you some idea.....love it and hit full boost by 4k rpm.!!
Old Dec 12, 2004 | 05:04 AM
what turbine A/R you have? 0.96 undivided?
Old Dec 12, 2004 | 07:56 AM
elnr's Avatar
0.96 undivided.....bear in mind response is subject to your tuning and porting.
Old Dec 13, 2004 | 07:03 AM
any idea how A/R 1.00 divided would work on FC with RB street port? What kind of rwhp should be expected @15psi at ??rpm?
inMotion719
Sep 28, 2015 03:09 PM
driftxsequence
NE RX-7 Forum
Sep 5, 2015 04:21 PM
sephalix
Dec 3, 2002 10:28 AM
Mikey_b
29
Sep 18, 2002 11:10 AM
NCsublime
Jan 6, 2002 01:42 PM
