Slightly bad housings.
Old Dec 4, 2004 | 11:02 AM
Fatman0203's Avatar
I just lost my motor to Haynes coolant seals. w/e no biggie, looks like the housings survived the heat and did not warp, but seems like dirt or something got in the motor and theres like a ripple effect (very very slight) on the inside on the housings. Is it possible to turn or lap the inside or should I look for new housings? (new or used )
Old Dec 4, 2004 | 11:38 PM
Trexthe3rd's Avatar
You cannot lap the housing, that will cause the housing to have excessive clearance for the rotors. There is a thread talking about coating the housing which would add material to the surface, jury is still out on that one.
The ripple effect is normal wear, the only way to know if it can be re-used is to check all the tolerances by the manual.
Old Dec 6, 2004 | 12:13 AM
Fatman0203's Avatar
anyone else about these ripples in the housings? you can not even see them, you can only feel them.
Old Dec 6, 2004 | 12:17 AM
SPOautos's Avatar
Hey, where did my $$$ go?
It sounds like your describing chatter marks. I'd get another one if it were me. Your not going to know how well it will work till you fire up the engine.....thats a pretty sucky time to realize its not working. I'd just get something else while the engine is apart.
toplessFC3Sman
Mar 20, 2018 01:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
The1Sun
Sep 18, 2015 07:13 PM
