strut tower bar
Old Dec 7, 2001 | 10:40 AM
bcty's Avatar
Boost This!
strut tower bar
i was wondering when you are installing the strut bar yoiu just remove the 4 bolts on the top of the tower and set the bar in and put the bolts back on right? when u release the bolt will the shocks/springs fall out, or... and do yoiu guys have any idea what is the best/biggest strut bar you can get? thanks
Old Dec 7, 2001 | 10:43 AM
niner's Avatar
just dont remove the bolt in the middle!!!!!
Old Dec 7, 2001 | 11:00 AM
FPrep2ndGenRX7's Avatar
Mazdatrix has a nice one that connects to the firewall and also has an engine torque brace. Kinda pricy though but you generally get what you pay for. If I had not made my own out of aluminum I would have bought theirs.
Old Dec 7, 2001 | 01:59 PM
Node's Avatar
yeah, the mazdatrix one always drew my attention in the pictures.
what about for rear strut tower bars, any suggestions?!
Old Dec 7, 2001 | 02:06 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
I heard you need to cut a hole in the strut towers for the rear one.
Old Dec 7, 2001 | 02:18 PM
FEDREX's Avatar
"Just Looking".......
Info on Mazdaspeed braces
Read my post at the bottom of this thread:
http://www.rx7club.com/vforums/showt...threadid=36987
The Mazdatrix braces are steel - just what I want, more weight.
Old Dec 7, 2001 | 02:33 PM
I'm going to make myself one. If you remove the carpet from around the rear strut towers you will notice on the front side of the towers two threaded holes about 1 - 1 1/2" apart. They are the mounts for the rear seat or something similiar to that. It is very easy to make the mounts and then have them welded to a cross bar. This bar will also double as my harness bar and a solid mount for my seat back brace. Depending on your fabricating skills and the desire to make this piece presentable it can look very good.
Old Dec 7, 2001 | 02:54 PM
cymfc3s's Avatar
I Raise Chickens
The mazdaspeed one you one have to cut small holes in the carpet. Not in the strut top.
Old Dec 7, 2001 | 06:29 PM
turboren's Avatar
I posted this in another thread regarding strut tower braces, but didn't get an answer. Can someone here explain this please?
What's the point in tying the rear of the LCA's together? doesn't that big *** engine crossmember provide enough lateral support on the bottom? Top I can understand, because it gaps a large hole, but the bottom seems pretty strong as is. Educate me, please.
Thanks,
Ren
Old Dec 7, 2001 | 09:23 PM
BhamBill's Avatar
If you're planning to autocross your car with SCCA, the triangulated brace is not legal in SP, but the straight one with the engine brace is.
Old Dec 7, 2001 | 09:31 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Thanks,
Ren
there is a big U shape underneith, the bar goes at the ends of the U where the LCA's are.
you can see here
Old Dec 8, 2001 | 12:32 AM
takerwolf's Avatar
I'll have a Ractive one for $50 if they ever get off their rears and make some more.
Old Dec 8, 2001 | 06:58 AM
87GTR's Avatar
I have the cusco
Front Strut Tower Bar
Front Low Arm Bar
Rear Carbon Fiber Bar
picks of my parts
The pics of my motor is old that was befor the
Haltec
T04
FMIC
this is how my motor looks now
http://rx7.cyberosity.com/87GTR/parts/Feb15-00-0006.JPG
Old Dec 8, 2001 | 08:50 AM
Node's Avatar
Was that just for him (cusco) or do you have to do it to other types of rear strut tower bars
Old Dec 8, 2001 | 03:23 PM
Scott 89t2's Avatar
SOLD THE RX-7!
what did you use the cut the rear holes?? my cusco CF is in the mail and I'll have it on Mon
Old Dec 8, 2001 | 04:23 PM
turboren's Avatar
you can see here
So, its purpose is to keep the rear of the LCA's in their original positions (i.e. not flex from lateral load)? Is this a common problem? I don't think I've ever heard of other strut-type cars having that problem. I would think the upper would be enough. Did you try to drive it with just the upper and see if adding the lower made a difference?
Ren
Old Dec 8, 2001 | 05:14 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I'm sure it doesn't flex much. but everyone who puts them on say they notice a difference. they make lower bars for lots of cars. FWD cars use them in the rear. the ITR's have them stock.
Old Dec 8, 2001 | 05:28 PM
turboren's Avatar
What's an ITR?
Ren
Old Dec 8, 2001 | 05:31 PM
Scott 89t2's Avatar
SOLD THE RX-7!
integra type R
Old Dec 8, 2001 | 07:48 PM
E6KT2's Avatar
Is that the Cusco in the big picture? That looks Awesome!
Old Dec 8, 2001 | 09:16 PM
87GTR's Avatar
To cut the holes in the towers, I used an small air jig saw. ( dont know the tech term for it) but it was about the size of large dremal tha I connected to my compresser and cut like jig saw.
the cusco gives you a basic diagram on where to cut. but would have been nice if they give you a normal template.
took a few fit checks to make sure they fit and would rub.
the carpet I was goig to cut a round hole in it to side the bar in. but desided to cut an X into it and put the bar throw the X.
Took about an hour to do everything. If I had to do it again my holes would not have been that large around.
