FD Stereo Install
Old Nov 26, 2004 | 01:13 AM
Jaymez's Avatar
Bye Bye FD , Hello MKIV
Angry FD Stereo Install
Hey guys I have done a search and havnt found anything to useful , im currently takein out the stereo deck that was in my FD when i purchased it, I have installed a DVD screen and it works perfectly , now my only problem is , getting the power cord from the battery to inside the **** pit(I have it currently down the passenger side , but i defiantly dont want that LOL).... I have looked everywhere and cant find a hole i can run the wire into . Any suggestions??
Old Nov 26, 2004 | 01:17 AM
iluvmy3rdgen's Avatar
I live in a Museum
What do you need the power cord for? If it's for the dvd, Why don't you use the existing power wire fromt he stock stereo?
Old Nov 26, 2004 | 01:21 AM
Jaymez's Avatar
^^ No idea , my friend is doing the install , he has a wire from the battery connected directly to the amp for the sub? He thinks we should drill a hole to feed the wire in? But I dunno.
Old Nov 26, 2004 | 01:25 AM
I live in a Museum
Oh, from the post i didn't know you had an amp or anything. Drill a hole, put a grommet in the whole, run the wire through. Make sure you put a fuse 12-18" from the + battery terminal just incase something happens. Explosions are bad.
Jaymez's Avatar
Where abouts should the hole be drilled? Any weak spots I should take advantage of?
Old Nov 26, 2004 | 02:19 AM
I live in a Museum
Drill the firewall close to the steering column grommet so it's easy to bring to the door sill ont he driver side.
Old Nov 26, 2004 | 03:14 AM
maxcooper's Avatar
WWFSMD
There are a number of spots to run wires through without having to drill metal, although perhaps the drilling isn't such a bad idea. Here's a few that don't require drilling the firewall:
- steering column at firewall -- slit rubber, feed wire through
- throttle cable thingy -- drill hole in plastic, feed wire through
- wiring harness -- remove fender liner, pop big seal out of hole, feed wire through hole, slit seal, replace -- be careful with the routing of the wires over the wheel, tire rubbing sometimes damages the stock wiring, so this could be a dangerous spot if you aren't careful
-Max
Old Nov 26, 2004 | 08:39 AM
broken93's Avatar
apex seal BBQ
Your best bet would be the driver's side wheel well hole. As maxcooper said there is an existing grommet there, and entry from the engine bay into the wheel well from a decent-sized hole under the ignitor box. I have all of my gauge wiring as well as a 4 gauge battery feed wire running through there. Once I popped the fender liner out (just take out the clips) and looked I was amazed at how easy it was to get wiring from one point to another.
From the interior, if you take the driver footrest out (cpl of bolts) and take the 10mm retaining bolts out of the fusebox, it will be a lot easier to access the hole. You have to poke something through the carpet liner from the wheelwell side.
Old Nov 26, 2004 | 10:37 AM
Jaymez's Avatar
Awesome thanks guys , makes my life alot easier LOL
Old Aug 25, 2005 | 02:42 AM
joeyz87's Avatar
drill a hole, use a rubber gromet to protect the wire its easy. dont mess with the factory gromets they ussually cant hold anymore wire especially 4awg.
Old Aug 25, 2005 | 06:59 AM
DamonB's Avatar
Bolgona. The large grommet in the driver side fender well is a couple inches wide and the fusebox/footrest protects anything you choose to run into the passenger compartment. It's the perfect place to run anything from the engine bay to the cabin and it doesn't require adding holes to the car.
I currently have an amp power cable, 1/4" rubber tubing for the boost gauge and wiring from my aftermarket temp sender all running through there and there's room for plenty more yet.
Old Aug 25, 2005 | 08:55 AM
Rx7Kidd's Avatar
Sp33d D3m0n
i ran my power cord next to the speedometer cable. on the outside of that rubber boot.
Old Aug 25, 2005 | 03:35 PM
Jaymez's Avatar
Wow I asked this question 9 months ago LOL. I did what DamonR said.
Old Aug 25, 2005 | 03:47 PM
iceman4357's Avatar
i drilled a hole in the firewall and ran it down the driver side kickplate to the amps. Just make sure to use the grommet
Old Aug 27, 2005 | 05:43 PM
7 BOUND's Avatar
127,338 OEM, 11.5psi
Dudeeeeee!!!!!!!!!!!!! Dont Drill Anything, Look There Is A Huge Huge Grommet Under The Drive Side Area, Its Were The Steering Wheel Rod Goes Into The Fire Wall, Get Some Pliars And Pull Toward You And Its Like A 5 Inch Whole There I Have All My Wires Running There, Dont Drill In The Fire Wall.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Enzo1944
Sep 6, 2015 08:57 AM
