Left rear Heater Hose
Old Nov 25, 2004 | 05:12 PM
Blvd43's Avatar
Angry Left rear Heater Hose
Does anyone know where to get the exact heater ose for the left side rear. I cant seem to locate it anywhere in WISC. I have check autozone, checkers and even napa or will I have to cut to fit the ******* hose...which I reall dont want to do. help anyone who has a resource ...thanks
Blvd43
Old Nov 25, 2004 | 05:19 PM
HAILERS's Avatar
HAILERS
http://www.mazdatrix.com/b.htm
Old Nov 25, 2004 | 09:28 PM
mwpayne's Avatar
Admitted 'rexaholic'
If that is the long one that has several curves/twists and goes under the oil cooler, I have a brand new one in the wrapper if you want it.
The mazda part #FB01-61-211C.
Old Nov 25, 2004 | 11:53 PM
RotaryEvolution's Avatar
Sharp Claws
that's the first hose to blow..
oh, and some people always tend to forget that a mazda dealer usually can get mazda parts.
mazdatrix likely has them also.
Old Nov 26, 2004 | 11:34 AM
torean's Avatar
vac leak
Well when I redid all my heater hoses, I bought about 4 feet worth from NAPA and had to cut to size. It was less than $3. I didn't think sizing was such a pain...
Old Nov 26, 2004 | 12:16 PM
ddub's Avatar
i am legendary
Are you talking about the one that goes from the block to the heater core at the firewall? Funny story, I just got this from Napa, it doesn't show up for Manual RX-7 but it does for Auto, and it's the exact same part. So if this is the hose you're talking about, go into a Napa and tell em your car is an auto and see if it comes up.
Old Nov 26, 2004 | 04:21 PM
autopilot's Avatar
ISeeWhatYou'reDoingThere
Mine blew just last week - I got a new one from NAPA.
Check your hoses now before it gets REALLY cold.
Old Nov 28, 2004 | 01:05 AM
Blvd43's Avatar
thanks everyone going to napa tommorrow ....hell finally got a day off
Old Nov 28, 2004 | 05:09 AM
Bob_The_Normal's Avatar
I was thinking of replacing those heater hoses... what would I look for at Napa, just generic heater hose? Doesn't it have to be "molded" or does that not matter? I'm pretty interested considering Mazdatrix wants $17/per haha...
--Gary
Old Nov 28, 2004 | 10:29 AM
Blvd43's Avatar
Thanks everyone and to Bob the Normal look at this
NAPA Belts and Hoses Hose - Heater
http://www.napaonline.com/cgi-bin/nc...3&prmenbr=5806
Click on image to see enlarged view
Front Item#: NBH10941
Price: $ 25.99
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Usually ships in 24 hours.
Attributes:
Attributes: Hose - Heater
I.D.(s): .62'' x .62'' x .62''
Length: 20.9''
Old Nov 28, 2004 | 11:06 AM
Blvd43's Avatar
From Gates Rubber Company
http://www.gates.com/part_locator/in...cation_id=3002
1986 Mazda RX-7 2-Rotor 1.3 L
Application Product Type Part # Comments
Belt Drive System
Front End Accessory Drive Components
Fan & Alt.
High Capacity V-Belt (Standard) 7320
P.S.
High Capacity V-Belt (Standard) 9420
A.C.; W/Nippondenso A.C. Compr.
High Capacity V-Belt (Standard) 9385
A.C.; W/Sanden A.C. Compr.
High Capacity V-Belt (Standard) 9380
Fan & A.P.; W/O Turbo
High Capacity V-Belt (Standard) 7355
Fan & A.P.; W/Turbo
High Capacity V-Belt (Standard) 7385
Cooling System
Coolant Hose
Upper
Molded Coolant Hose 20380 (A)
Flexible Coolant Hose (Standard) 25804
Lower
Molded Coolant Hose 20900
Flexible Coolant Hose (Standard) 25473
Heater To Eng.; W/Auto. Trans.
Molded Heater Hose 18941
Pipe To Eng.
90º Molded Heater Hose 28467 Cut to fit
Eng. To Throttle Body; W/O Turbo
Molded Heater Hose 18021 Cut to fit
Throttle Body To Valve
Straight Heater Hose (Standard) 28408 (16")
Valve To Intake Manifold; W/Turbo
Molded Heater Hose 18020 Cut to fit
Radiator Caps & Testers
Radiator Cap
Safety Release Radiator Cap 31533 Check hood clearance prior to installing this cap
Regular Radiator Cap 31333
Cooling System Adapter
Radiator Cap/Cooling System Tester Adapter 31428
Cap Adapter
Radiator Cap/Cooling System Tester Adapter 31378
Thermostats, Seals & Gaskets
Thermostat
Premium Thermostat 33188S
Regular Thermostat 33188
Thermostat Gasket
Thermostat Gasket 33644
Fuel System
Fuel Caps & Testers
Fuel Cap
Regular Fuel Cap 31613
Regular Locking Fuel Cap 31708
Fuel Cap Tester Adapter
Fuel Cap/System Tester Adapter 12410 (Threaded) Threaded adapter connected to tester
Oil & Lubrication System
Oil Caps
Oil Filler Cap
Oil Filler Cap 31083
Steering System
Power Steering Hose
Pressure; W/12mm End Fittings
Pressure Line Assembly 359820
Pressure; W/16mm End Fittings
Pressure Line Assembly 358890
Return - Cooler To Pump
Multi-Use Return Hose (Standard) 350010 (10")
Old Nov 28, 2004 | 03:48 PM
Blvd43's Avatar
I also found a Advance auto part hose too... see below
Drive-Rite 304360
MOLDED HEATER HOSE
http://www.partsamerica.com/PartDeta...tNumber=304360
diabolical1
30
Jan 30, 2016 05:50 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
