timing on semi pp motor
Old Nov 22, 2004 | 03:48 PM
wickedrx2's Avatar
i need some help on tunning a 13bre cosmo block which i semi pp ported
, im running a t72 the block has 9.4 rotors, i heard people running timing retard as much as 24 deg on leadings ,im using a locked distributor at 12 btdc on leading and 2 for trailing , the car pop so then i rearded the timing 15 btdc on leading and 5 trailing and cleared a bit more but still pop a lil bit, im runing 20 psi on manual boost controller this is on my 74 rx3
thanks julio
Old Nov 22, 2004 | 10:44 PM
Marcel Burkett's Avatar
Put a wide band on it first an see what a/f ratios you're running . Excessive popping usually means that you're running rich. As for the timing , I dont mess with mechanical distributors , but I think 13-15 deg. @ 15psi and up is advance on the leading is "standard" on a turbo rotary.
Old Nov 23, 2004 | 04:12 PM
speedturn's Avatar
I haven't heard of a "semi" pp motor..... is that like being a little bit pregnant?
Old Nov 25, 2004 | 04:36 PM
wickedrx2's Avatar
semi pp means keeping all your original ports and adding a smaller pp 1" to your rotor housings
Old Nov 26, 2004 | 01:58 AM
Jeff20B's Avatar
Lapping = Fapping
speedturn, you used a Blake-ism.
Old Nov 26, 2004 | 06:43 AM
KNONFS's Avatar
B O R I C U A
When I was tunning my car for emissions, it used to pop a lot at 14.4-14.8 AFR (under vac).
BTW - I am not saying you are wrong, just sharing my experience.
Old Nov 26, 2004 | 05:39 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
what kind of gas?
Old Nov 27, 2004 | 04:07 PM
KNONFS's Avatar
B O R I C U A
Originally Posted by GUITARJUNKIE28
what kind of gas?
Either 87 or 89 (can't rember which) on a overdose of premix.
Old Nov 28, 2004 | 01:38 AM
big turbo + high compression + lots of overlap + pump gas = BOOM
i'd start really low...like maybe 10 and get it on the dyno and pay really close attention to egt's. how much boost?
dkwasherexd
May 27, 2017 04:51 AM
PhillyFC
Aug 21, 2015 06:36 PM
sYnth.
Aug 19, 2015 06:27 PM
befarrer
Aug 14, 2015 04:18 PM
