Rear and Front Speaker Sizes??
Old Dec 5, 2001 | 03:59 PM
RavenRx7's Avatar
Can anybody tell me so i dont have to take it all apart to find out. They look like 6 x 9 's -- Bose's right?
Old Dec 5, 2001 | 04:26 PM
jr's Avatar
jr
On the non-Bose systems the front doors are 6" speakers (odd ball size) which can be replaced with 5 1/4's using an adaptor bracket, 6 1/2"'s will NOT fit. The rears are 6x8"'s. I have no idea what the Bose systems have.
Old Dec 5, 2001 | 09:25 PM
misdbman's Avatar
Just did all 4 in my base model this summer. 6x8 in rear, and I DID get 6 1/2" thin-mount Pioneer's in the doors. Doors were perfect fit, no cutting and screwed directly into the holes. You have to take that plastic crap off the front speakers first to unscrew them. If you don't believe me, I can take a digital picture since I have my door panel off to fix the map door and power window switch.
Old Dec 5, 2001 | 10:44 PM
jr's Avatar
jr
I believe you, just didn't work for me. I tried putting in Infiniti Kappa 6 1/2's in there and it wasn't even close. I'd like to see the pics if you have them to see if maybe I can do something differently to make them fit. Do you know what the mounting depth on your Pioneer's are? Thanks.
Old Dec 6, 2001 | 09:24 AM
RavenRx7's Avatar
Unhappy
that 's what i was going to put in --infinity kappa's so they will NOT work that sux
Old Dec 6, 2001 | 11:13 AM
misdbman's Avatar
I'll need to check on the depth. You are right that any "meaty" speaker will not fit. I first went for some better high-end speakers, but I could not see how such a large magnet was going to fit, even if I cut the plastic of the enclosure to give more room to the window. It looked like even if I used 1/2" spacers I was going to have problems. So I returned them and went with the low profile Pioneers. I still have the box so I can get the depth for you. I don't have a jamming system, so the Pioneers all around work fine for me. Sounds much cleaner than stock. I found the higher-end speakers sounded crappy without an amp. I'm trying to stay with the 'lite' theme, plus I screwed up one ear at a concert. No more amps for me...
Old Dec 9, 2001 | 10:06 AM
misdbman's Avatar
My front Pioneer's are 1 5/8" in depth. Pretty thin. I don't think you can go much over 2" without cutting the plastic behind the magnet and using spacers.
Old Dec 9, 2001 | 05:51 PM
RX794's Avatar
NYC's Loudest FD
What are the Pioneer front speakers that you used? Are they the TS-1620II's ?
Old Dec 9, 2001 | 06:05 PM
misdbman's Avatar
1625's, 100w.
FD7KiD
15
Feb 26, 2021 10:12 PM
tridav3
Interior / Exterior / Audio
Aug 18, 2015 11:42 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
