lightweight rotors
Old Nov 11, 2004 | 10:14 AM
calculon's Avatar
On flats
lightweight rotors
anyone know where to find lightweight rotors for the 20b?
Old Nov 11, 2004 | 12:35 PM
Falcoms's Avatar
kill it with BOOMSTICK!
I think if you ask Racing Beat really nicely and send them your e-shaft, they'll set you up with they're light weight rotor assembally(sp? I know it's wrong). While you're at it, might as well get the flywheel and clutch you'll be running and have them balance the whole rotating assembally(sp). Just my $.02, even though it's not worth that much nowadays.
Old Nov 11, 2004 | 12:45 PM
Evil Aviator's Avatar
Rotorhead
http://www.mazdamotorsports.com
Old Nov 11, 2004 | 09:30 PM
Drag'nGT's Avatar
working towards the goal
There can't be that much of an advantage to spending that much money on rotors.
Old Nov 12, 2004 | 12:05 PM
calculon's Avatar
On flats
main advantage is a higher redline, additionally, longer engine life (puts less strain on the eccentric shaft and bearings)
Old Nov 12, 2004 | 01:11 PM
fi addict's Avatar
a new counterweight would be needed w/ these rotors? is this correct?
seems that if you lighten one end the counterweight would need a trimming too.
Old Nov 12, 2004 | 05:11 PM
RX-Heven's Avatar
I'll blow it up real good
Some shops can lighten your existing rotors to achieve the same wieght.
Of course then rotating assembly has to be revalanced then.
sinclair7seven
11
Sep 11, 2015 10:15 AM
