??? HOw to get stock mazda emblem glue off
Old Nov 5, 2004 | 06:08 PM
SpiritRex7's Avatar
Antracite Supra
as the title states... I just got my car back from the body shop and i asked them to do it for me but i guess they forgot... whats the best solution, my car looks amazing now it looks sooo good I dont want that little crap to ruin it.
Scott
Old Nov 5, 2004 | 06:30 PM
Sonny's Avatar
R1derful
Use a big giant super sharp screwdriver and hammer.
I've used a hairdryer before to remove emblems.
Sonny
Old Nov 5, 2004 | 06:40 PM
Black97VR4's Avatar
FEARED
Heat gun and careful use of a credit card can work great. There will be three holes to fill though if you don't plan on adding another emblem.
Old Nov 5, 2004 | 06:43 PM
adam c's Avatar
Cheap Bastard
Take it back to the body shop, and ask them to do it. They are professionals, and should know what they are doing
badddrx7's Avatar
All Spooled Up
Do not use anything harder than your fingernail...I used Simple Green on a soft cloth and plenty of elbow grease. It will come off,,,,slowly. Then use a good wax to finish it off.
Tom
Old Nov 5, 2004 | 08:19 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Use a rag and some denatured alcohol. It will rub right off. The alcohol wont hurt the paint.
Old Nov 5, 2004 | 09:45 PM
seanbrowning's Avatar
Yeah, alocohol. I use it for sap all the time, if it gets that crud off, that glue will just melt like butta.
Old Nov 5, 2004 | 11:24 PM
jeremyb's Avatar
Hi....
i had a funeral sticker on my car and the idiot usher for the funeral stuck that **** on my winshield without my consent. i used goo gone and just let it soak and i wiped it.
Old Nov 5, 2004 | 11:27 PM
Falcoms's Avatar
kill it with BOOMSTICK!
Goo gone is god-like in its abilities. Ranks up there with simple green
Old Nov 6, 2004 | 01:45 AM
SWAT81's Avatar
8AN5H33
Tom
what I did and worked like a charm
Old Nov 6, 2004 | 02:09 AM
KaiFD3S's Avatar
SINFUL7
I used lighter fluid, it softens the glue then just wipe it off with a soft cloth...after that just wax that area, I did it on mine and it worked great...did not hurt the paint at all..
Old Nov 6, 2004 | 02:23 AM
akiratdk's Avatar
The Laser Man
use a product used by 3m most car body shops use it and its paint safe.... its called adhiesive remover. YOu can get them at paint shops.
Old Nov 6, 2004 | 03:20 AM
mitchelrl's Avatar
Actually, there's some stuff at Home Depot, similar to Glue Gone.
except it's all organic and will not mess with your paint in any way shape or form.
Best advice I can give you though is to let the liquid do most of the work, don't scrub it. Get it wet on a towel and hold it on there for a minute or too. then gently thumb it off, if you don't mind a few swirls though, you can scrub it a little with the towel as well.
3M adhesive remove does WONDERS. The best detailers out there use it.
Old Nov 7, 2004 | 09:30 AM
witepsycho's Avatar
i used goo gone and it started softening my paint
Old Nov 7, 2004 | 04:47 PM
moktan_fdtt's Avatar
3m has a professional product that removes goo, it is paint safe and only cost about $9, well worth it.
Old Nov 8, 2004 | 07:01 AM
DamonB's Avatar
I just swapped out my stock emblems recently. The adhesive on my car was dried up and crumbly. I picked the majority of it off the paint with my fingernail. The trouble spots I soaked in an adhesive remover and then picked with my fingernail again. After that I used a clear coat safe polish and lots of elbow grease to clean up the area before applying the new emblems. On my car if you look closely you can still identify where the old emblems were because the paint is slightly distorted from the old adhesive. I guess 12 years will do that.
Old Nov 8, 2004 | 12:58 PM
iluvmy3rdgen's Avatar
I live in a Museum
My friend told me a trick to remove mine and it worked quite nicely. Just soak it in lighter fluid, then use a piece of fishing line to seperate the glue and remove the emblem from the car. I did this and it came off pretty easy, then just use some more lighter fluid and your finger to remove the extra paint. This works great but if you are having trouble just use a lot of lighter fluid then find a match
Old Apr 14, 2005 | 09:51 PM
TurboLumpy's Avatar
They took our jobs!
figured id resurrect an old thread rather than start a new 1... just wanted to know what type of adhesive you guys would recommend to put on my new efini emblems
Old Apr 14, 2005 | 10:21 PM
NuTbAgSaN's Avatar
triangles
yeah the 3m stuff...laquer thinner stuff. i worked in a bodyshop for awhile + i used the **** to get my front emblem off. 1st use like...wtf i cant think...just something to pry it off, be careful of course, then use the thinner on a rag and it will get that **** off easy, no hard scrubbing. paint safe.
Old Apr 14, 2005 | 10:24 PM
NuTbAgSaN's Avatar
triangles
^^ and go find some emblem adhesive. dont know if its anything special but thats what they use...so y not? damn wish i still worked i would just grab u some.
Old Apr 14, 2005 | 11:24 PM
seanfd3s's Avatar
airplane apex seals
yep, did that to my friends wrx's but they had no holes
Old Apr 15, 2005 | 09:16 AM
gcthree's Avatar
Use a heat gun to soften up and remove the bigger globs, and then use Finish Line concentrated citrus biosolvent (you can get it at a bicycle shop) to remove all traces of the glue residue without any damage to the paint...plus, it smells good! it's a terrific degreaser and cleaner that you'll continually use.
Old Apr 15, 2005 | 12:20 PM
ranchan02's Avatar
I just did mine about a month ago. It's held in place by these tabs and some glue. The glue that held the original emblems in place lost most of it's holding capability, so I was able to pull them off (slowly). To get the old glue gunk off of the body, I just used some WD-40 and a old T-shirt and the gunk came right off.
Old Apr 15, 2005 | 01:19 PM
Brent 94's Avatar
Is he taking off the front emblem or the rear?? I know the front emblem has the 3 prongs and thats why i haven't touched the back emblems. I'd like to take my rear emblems off but don't want to have to fill any holes or anythign like that. Are there prongs on the "mazda" or on the mazda emblem on the rear???
Old Apr 15, 2005 | 01:31 PM
DamonB's Avatar
The front logo, rear logo and Mazda emblems all have prongs. The RX-7 letters have no prongs. I just replaced all my emblems recently.
