SHES ALIVE AGAIN!!!! but now
Old Nov 4, 2004 | 09:17 PM
Fitness Stain's Avatar
Yar-Har-Har
okay as some of you may know after getting my car back from landers, it ran great for a weekend and then wouldnt stay started ...
i thought it was the afm so i wait to get one in the mail ...
it comes i put it in, and nothing changes ...
kevin suggested that i checked the safc wiring to make sure nothing came loose or what ever ..
so i check it , and everything is still connected, so i isolate the safc and just put the stock afm wiring back together ... sure enough the bitch fires right up and stays started >.... WOOOOHOOOOO!!!
so i reattached the safc, and shes running just fine again ..
one thing though ...
the TACH is not responsive ...
i checked the safc to monitor the RPM, and it doesnt see any either ...
the tach jumps when i start the car so i know its not dead, ....
i assume the wire is loose for the tach as well, so off i go ...
just figured i would give an update to this, as i didnt want to make it sound like kevins engine wasnt running right ... cause the engine is rocking, and ive never been happier behind the wheel of my rex
THANKS KEVIN!!
=-dustin
Old Nov 4, 2004 | 09:21 PM
RETed's Avatar
Verify the trailings coils are firing?
It might be dead.
-Ted
Old Nov 4, 2004 | 10:32 PM
Falcoms's Avatar
kill it with BOOMSTICK!
It might be dead.
-Ted
That'd be my guess, too. The tach is run off of the signal from the trailing coil, so if the coils dead, there is your problem with the tach and the faliure to keep running.
Old Nov 4, 2004 | 11:49 PM
Yar-Har-Har
***update***
the RPM (green) wire on the safc to the wire on the harness (ECU side) was connected, but something was wrong with it ... not sure what, but when i reconnected the ecu wire bypassing the safc wire it worked for a second, then died again ... so i messed with it for a while and ended up cutting the spliced section out, (it was spliced to "T" the safc wire into it), and running a new wire between the cut ... started it up and it worked like a charm !!
so i then just attached the safc RPM wire to that new wire, and BAM!! its all good ...
im not good a soldering, so as soon as either garfinkle or rotorbrain can , im gonna get them to solder those connections together so i never have to worry about this crap again ..
anyway .. .long story short it was the SAFC the whole time causing my woes ...
anyway ... thanks for the reply's, and i gotta go drive now!!
=-dustin
Old Nov 5, 2004 | 06:58 AM
Fire85GSLSE's Avatar
Chad Carson
Originally Posted by Fitness Stain
***update***
=-dustin
Make sure you solder it, heat shrink tube it and you should never have another problem out of that connection.
I have portable butane soldering gun that I bought when I graduated from I.T.T. and went to work for GE Medical installing and repairing hospital equipment.
If we all get together again soon I wil bring it, and some heat shrink tubing.
Chad
Old Nov 5, 2004 | 09:56 AM
Yar-Har-Har
man i get the damn tach working great last night .. reinstall the kick panel ... restart it to get it out of the garage, and park it outside ..
get out there this morning, and the damn thing is dead again ... either that wire is being stupid or the trailing coil is going out ... but i assume its the wire , as it works for a minute and then doesnt ... retap the wire, and it works great again ... and then this morning it doesnt
Old Nov 5, 2004 | 11:20 AM
Parastie's Avatar
Mountain Rotary Mod
Ha! Thought it was the SAFC! Good to hear it's running!! Make sure the TAC wire going into the ECU is still in place.
Old Nov 5, 2004 | 11:32 AM
Yar-Har-Har
i attached it last night, and it worked, but started it up this morning, and the tach is dead again ... its that stupid wire .. i guess it just needs to be soldered in there before it will stay ...
poop
Old Nov 5, 2004 | 12:59 PM
jimmyv13's Avatar
Round&Round not Up&Down
Are you using anything to hold the two wires together? Tape will not do...try wire nuts until you can get them soldered.
Old Nov 5, 2004 | 01:32 PM
Yar-Har-Har
i should be able to get them soldered by sat. day ... just gotta get in touch with a few guys i know that are handy with the ol soldering gun ... i could probally do it, but its tooooo close to the ECU and it just makes me really paranoid
hopefully that takes car of it ... im tired of ripping up the carpet and taking out the kick plate
Old Nov 5, 2004 | 01:35 PM
RotaryEvolution's Avatar
Sharp Claws
sounds like a spread pin in a connector to me.
squirrels
Sep 1, 2024 09:52 AM
jdmbrendan
Oct 1, 2015 01:29 AM
