where are the holes in the firewall?
Old Nov 4, 2004 | 06:52 PM
BlueSteel's Avatar
No destination.
i need to run a power wire for an amp thru the firewall and i really dont wanna drill it... anyone know a good hole that already exists/can b used for this?
Old Nov 4, 2004 | 07:05 PM
speeddemon32's Avatar
No more 7 or 8
i always use the hole that the spoodo cable goes through. just knock out the plastic outer plub, and it works great.
Old Nov 4, 2004 | 07:22 PM
BlueSteel's Avatar
No destination.
does that mean im going to have to remove my gauges again? (already spent days fighting them to install the blue faces)
Old Nov 4, 2004 | 07:31 PM
No more 7 or 8
not at all......
Old Nov 4, 2004 | 07:37 PM
13b_drifter's Avatar
Tarmac Surfer
Now why didn't I think of that. Ive been trying to find a place to run the hose for my damn boost gauge...lol
Old Nov 4, 2004 | 07:54 PM
BlueSteel's Avatar
No destination.
lol sry speeddemon but ur gonna have 2 clarrify 4 me. where exactly will the wire come into the cabin?
Old Nov 4, 2004 | 08:04 PM
No more 7 or 8
no problem, under the dash, kind behind the gas pedal is the speedo cabel running through a plastic "casing" just pull the casing out. (i think i did this from the engine bay side.)
it leaves you with a nice big hole with nothing but a speedo cable. (or throttle cabel.,... but i think its the speedo)
Old Nov 4, 2004 | 08:56 PM
BlueSteel's Avatar
No destination.
would u recomend putting this casing back in, so nothing gets in it?
Old Nov 5, 2004 | 10:28 AM
No more 7 or 8
no you cann't the inner hole is only big enough for the speedo cable.
unless you find a way to drill out the center.
its all up to you, i didnt, i just had a little hole in the fire wall
(after 4 guage, 8 guage, and all acc. wires, the big hole wasnt so big anymore.)
Old Nov 5, 2004 | 10:32 AM
Aaron Cake's Avatar
Engine, Not Motor
The chassis wiring harness enters through a rubber grommet underneath the clutch master cylinder. That is the ideal place to run wires (especially thick ones). While it's a little bit of a pain to get to, it is well protected and has plenty of space to fit even thick cables.
Old Nov 5, 2004 | 10:33 AM
No more 7 or 8
ill have to try that next time.
thanks
Old Nov 5, 2004 | 05:48 PM
Syonyk's Avatar
Would one of those be a good place to run mechanical gauge senders through as well? Obviously protect the tube with something.
-=Russ=-
Old Nov 5, 2004 | 06:46 PM
patman's Avatar
Resident Know-it-All
ever heard of a drill? lol. i have no AC, so i have lots of good places. On cars with AC, i usually drill a new hole, but if you dont like that idea, run it thru:
A) wire harness hole (under clutch master cylinder, or by cruise control thing if its on the pass. side.
B) Steering column hole...works good, and very easy to get to, but make sure it cant get caught on the bolt that sticks out and wrap around the column.
C) speedo hole or one of the AC holes
pat
Old Nov 5, 2004 | 06:47 PM
patman's Avatar
anybody know why my damn sig doesnt work?
djessence
Oct 4, 2015 10:21 AM
pfsantos
Sep 30, 2015 01:29 PM
