advice
Old Nov 4, 2004 | 08:39 AM
mazdarx7conv's Avatar
advice
i park my car outside because we only have a 1 car garage, but its getting cold out here. i think ill just stick the cover on it the first time the temp gets below freezing. is there anything i should know such as i need to start it every week or somthing. cause i dont want my car to sit all winter and not be able to start when things thaw out.
Old Nov 4, 2004 | 08:51 AM
SureShot's Avatar
Seduced by the DARK SIDE
Make sure the anti-freeze is good & fresh.
Add some stabilizer & pre-mix (2-stroke oil) to the gas.
Run it for a minute.
Shut it off & disconnect the battery.
Tuck it in for the winter.
Old Nov 4, 2004 | 10:10 AM
Dltreezan's Avatar
My Bick is Digger
thanx sureshot
Old Nov 5, 2004 | 08:42 AM
yeah thanks
Old Mar 22, 2005 | 01:56 PM
SureShot's Avatar
Springtime startup:
Check & connect the battery
Put some cheap fuel injector cleaner in the gas.
--(It is lame at cleaning injectors, but the alcohol in it will sweep up any condensed moisture in the fuel.)
Start it up.
Andrew7dg
Aug 6, 2017 01:41 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
Zinraf
Oct 1, 2015 01:09 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
risingsunroof82
Sep 7, 2015 01:11 PM
