Question on FSM Wiring harness Diagram?
On the emission harness Diagram it has the different injectors specified by a code
"R-P"
"R-S"
"F-P"
"F-S"
I'm assuming this is Rear primary/front primary, Rear/front secondary, correct?
Just double checking. I need to re-run these wires from the ECU to the injectors. I believe there is a fault in the wiring.
"R-P"
"R-S"
"F-P"
"F-S"
Well here is my plan, Just checking this is the right way to rewire the injectors from the ECU to the plug... the color specific wire (LG, LG/B) are pretty obvious... But what about the B/Y wires? Are they specific? there seems to be multiple ones and I'm not sure what corresponds to where?
82streetracer
Aug 23, 2015 09:28 AM
