Auxilary port actuation rods repair/rebuild possible?
Old Nov 3, 2004 | 01:27 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Hey all a while ago I swapped my LIM because the front rod had become stuck for some reason. Other than that the manifold is good. I want to know if I can somehow fixt the siezed rod. I haven't been able to remove it from the manifold yet. Is there a procedure for this in the FSM or something in the archives?(I didn't think there was because I haven't seen anything in the time i've been here on it)
Old Nov 3, 2004 | 02:21 PM
RotaryResurrection's Avatar
You sometimes can, but not always. First is to soak it in penetrant from both sides of the rod. Try to get it spinning, a little bit at least. Then try to remove it, with pliers on the outer end. You can't really hit or push the inner end, it has a spring in the middle. Sometimes theyre stuck (s5's especially) bad enough that the rod snaps before you can get it out.
Old Nov 3, 2004 | 02:39 PM
1987RX7guy's Avatar
what kind of penetrant do you use? I normally use PB or WD40
Old Nov 3, 2004 | 03:38 PM
ceodre's Avatar
same problem here
Old Nov 3, 2004 | 04:45 PM
Tofuball's Avatar
Jesus is the Messiah
I soak it in WD-40, put a used sleave (or other cylender to keep the spring from flexing) then I just hammer everything out. You can do it without the cylender if you hit it lightly and square enough, but I wouldnt want to bend that spring, it would make reassembly hard.
Then wire-brush the rod, and file/sand/polish out the inside of the brass rod guide.
Then lube it up and you're good to go! (I also replaced those stupid screws with bolts)
24seven_dada
20
Nov 10, 2018 12:03 PM
alexdimen
20
Oct 23, 2015 01:50 PM
doritoloco
Sep 5, 2015 12:41 PM
