my rx7 won't start
Old Nov 2, 2004 | 07:29 PM
newbie to the rx7's Avatar
first RX
my rx7 won't start
I tried taking the plugs out and spray the fuel out the spark plug holes and then I put tranny fluid in the holes and when I tried to start it and it ran for about 30 seconds then it quit. when I started rolling it there was a puddle of gas I think the fuel pump might be gone does this sound right. i also think that there is a hole in the line.
Old Nov 2, 2004 | 07:43 PM
WAYNE88N/A's Avatar
How many miles on the engine? Done a compression test?
If she ran for 30 seconds, then the pump WAS working, at least...
Umm, hole in the line should be easy to spot (or smell)...
When was the last 60K tuneup?
Old Nov 2, 2004 | 07:54 PM
RotaryEvolution's Avatar
Sharp Claws
first thing is first, check for the fuel leak, fix it, then recheck the car.
even a moderate fuel system leak can cause your pressure to bleed down enough that it would only run for a short period.
alphawolff
Nov 17, 2015 05:57 PM
Im faster
Aug 19, 2015 02:57 PM
86glxNA
Aug 18, 2015 03:33 PM
86glxNA
Aug 15, 2015 01:45 PM
