Seatbelt light.
Old Nov 1, 2004 | 06:29 PM
Mason Rx7's Avatar
Dancing w/ teh devil...
Seatbelt light.
I was an idiot today and let my battery die. After I got it jumped I noticed that the selt belt didn't immediately retract... I've got a S5... Anyways... The seatbelt light stays on till I've driven for about five minutes and then turns on again after until I turn off the car and start it again. The seatbelt seems to stay in place for about five seconds after I open or shut the door.
Should I just pull off the negative battery cable and reset the problem codes? What's going on here?
Old Nov 1, 2004 | 06:37 PM
Makenzie71's Avatar
...94% correct.
The seatbelt and light only do that when there's a loose nut behind the wheel. Remove it and all will be good.
Old Nov 2, 2004 | 02:29 PM
vaughnc's Avatar
knowledge junkie
Open the door & press the sensor/switch in the door sill area to simulate the door closing. Does the autobelt retract or is the sensor/switch seem to be a bit shorted?
TwentyDW
Sep 2, 2015 06:42 PM
