car sat up from a month, now it has problems......
Old Nov 1, 2004 | 05:54 PM
rx_7_driver's Avatar
simple as this, i parked the rex for about a month or so. now it has some odd problems:
- brake booster no longer works
- having cooling problems, not overheating. air is getting into the system it seems. had the system flushed and pressure tested. no leaks were found and no white smoke out the pipe. car is still getting 23mpg. and can go about 300 miles before needing water.
the car is a 86 n/a. i suspect the water pump to be part of the problem (new mazda thermostat) new coolant.
thanks for anyhelp u can give me.
-Shawn
Old Nov 1, 2004 | 06:05 PM
Innovation's Avatar
You can go 300 miles without needing water? I can go 3000. Sounds like a leak or it's getting boiled off. Bring it up to temp. and check for any weeping near the water pump and all the hoses.
Old Nov 1, 2004 | 06:09 PM
turbine's Avatar
check your rad caps if you cannot find a leak else where
Old Nov 1, 2004 | 06:12 PM
DerangedHermit's Avatar
Check the weep hole.
Old Nov 1, 2004 | 06:14 PM
cap is new (from dealership also), water pump is still the orginal, 165k on it. it also weaps (makes odd noise). i will replace it as soon as i got some cash. should i go buy a cheap one at advance auto or should i go all out with a mazda one?
-Shawn
Old Nov 1, 2004 | 06:17 PM
The Spyder's Avatar
Never give up!
There what? $60 from atkins?
alphawolff
Nov 17, 2015 05:57 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
