S5 TII cat question
Old Nov 1, 2004 | 10:32 AM
speeddemon32's Avatar
No more 7 or 8
S5 TII cat question
I have a S5 Turbo II.
My question....
Does this car have a "fresh air tube" that run to the Cat like the S4 Turbo II?
because i cant find ware it goes if it does....
Thanks!
Old Nov 1, 2004 | 10:38 AM
SureShot's Avatar
Seduced by the DARK SIDE
The stock cat had a fresh air pipe.
Maybe you have a replacement cat..
Old Nov 1, 2004 | 10:41 AM
No more 7 or 8
i cant find ware it goes to the manifold. the cat i have has a hook up for it, but i cant find ware it goes on the manifold, dont see ware anything is pluged off either.
Old Nov 1, 2004 | 10:48 AM
dr.jones63's Avatar
It's a Hammer
Yes, check the online FSM found in the Sticky: FAQ for FC
Old Nov 1, 2004 | 11:24 AM
HAILERS's Avatar
HAILERS
One inch aft of the acv. See the two studs? Next to the water outlet for the turbo. It sounds like you missing the mating pipe w/flange.
Old Nov 1, 2004 | 03:21 PM
dr.jones63's Avatar
It's a Hammer
I have block off plates but this is the location on the engine where the split air pipe pipe hooks up. Center of the picture, right above the turbo. left of the dioganal red hose, the ACV block off plate is on the right.
HDA
Nov 3, 2015 03:49 PM
yetter227
20
Sep 5, 2015 11:57 PM
rx7shirley
Sep 2, 2015 02:11 PM
12abridgeport
Aug 17, 2015 06:28 PM
