need clarity on the rotary resurrection 6th act.
Old Nov 1, 2004 | 08:08 AM
Whizbang's Avatar
Respecognize!
Exclamation need clarity on the rotary resurrection 6th act.
okay reading the tech article on the site, it says that you need one or two of the engine vac. soleniods. I have an 87 n/a and i straight pipe the car. menaing i have to use the electric activation. But i m confused what it means by one or two. Do i need an additional soleniod off another car? or do i just use the ones that are there? I am orderinng my MSD switch today and pills, then i guess i am going to get started on the wiring setup also. But i to know what EXACTLY i am doing with the 87 N/A Vac solenioid setup.
Old Nov 1, 2004 | 08:22 AM
Whizbang's Avatar
Respecognize!
oh one more Q, can i do a emissions removal now? or is the vac soleniod in the rats nest?
Old Nov 1, 2004 | 08:41 AM
Mx6-Rx7 Addict's Avatar
Brap Brap Brap
If you are concerning the 5/6th ports opening, then you don't need to do anything, for the ports are opened up by exhaust back pressure via the split air tube. As far as rats nest removal, you can remove them, you will have to run some fuel line, and you might want to leave the soleniod controlling hot start (i think?) it's an orange plug on the soleniod. I forget, i know it rises fuel pressure though
Old Nov 1, 2004 | 08:43 AM
Whizbang's Avatar
Respecognize!
no cat = no backpressure going through the pipe = need activation
Old Nov 1, 2004 | 09:13 AM
Icemark's Avatar
The summit switch will be wired to switch a vac solenoid.
The input of the vac soleniod will be hooked to the air pump, while the output of the solenoid will be hooked to the input of the aux ports.
Old Nov 1, 2004 | 09:14 AM
Whizbang's Avatar
Respecognize!
the summit ramps the voltage which is a little funky. But it can be done with the MSD one correct?
Old Nov 1, 2004 | 09:16 AM
Whizbang's Avatar
Respecognize!
lol! i hope i can get this done by friday!
Old Nov 1, 2004 | 09:17 AM
Icemark's Avatar
Sure... all you need is a switch that outputs 12 volts or ground at a set RPM.
Old Nov 1, 2004 | 09:19 AM
Whizbang's Avatar
Respecognize!
we are still on the i am removing the emissions page right?
Old Nov 1, 2004 | 09:23 AM
Icemark's Avatar
Well you will need to retain the air pump and a vac solenoid to make the aux ports work (as well as a vac solenoid for fuel pressure).
Old Nov 1, 2004 | 09:26 AM
Whizbang's Avatar
Respecognize!
well i got a few days to fiddle around with it. i am going to use the walmart $15 air pump motor idea to follow the original directions as a base. Seeing this is first time i am messing around with the motor's operations like this, i dont want to get too creative.
Old Nov 1, 2004 | 09:39 AM
Icemark's Avatar
HMmm , well I can't recommend that approach, but even if it doesn't work, its just the aux ports that would not be working and you can still drive the car.
Heck, 15-20% of the non turbo owners probably have stuck aux ports anyway and don't even know it. That is why you see some many bogus "wired my ports open and got tons of HP" threads.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
