No oil
Old Oct 31, 2004 | 05:01 PM
spank1's Avatar
faster
No oil
A brain dead oil change person forgot to put oil in my FD at the mazda dealer in
my area. The car was driven from service bay to wash bay and then to check out.
I got in and started to drive out looked at the gauges saw there was no oil
pressure and turned the car off. Since the turbo timer was on I think the car
ran for 3-5 minutes during this process. They pushed the car back to the service
bay and I watched them put oil in it. It started right up with pressure and did
not smoke. So far everything seems to be fine but I wounder about the long term.
The tech on duty said of cource they would pay for any proplems that this might
have caused. He wrote it all down so I have documentation. Should I take my
car to a third party to have it checked out as I don't trust this dealer any more?
Old Oct 31, 2004 | 05:16 PM
WaLieN's Avatar
Call me gramps!
If there REALLY wasn't any oil in there, the oil level sensor should have gone off. They were possibly just topping it off. As for the stock oil pressure gauge, often times it is just a faulty sender.
Old Oct 31, 2004 | 05:27 PM
Fumanchu's Avatar
Belligerent Security
Ojai huh? What dealership did you take it to? Oxnard? You really need to be doing your own oil changes. You save money and you know it will be done right.
If you would rather take it somewhere, drive it up to Mariah's in SB www.mariahmotorsports.com. They know what they are doing. The next closest rotary shop to you would be Tri-Point in the valley. http://tripointengineering.com/ . Also, the So Cal RX Club has their meetings in Camarillo every month. You can meet up with some local owners and ask any questions. http://www.socal7s.org/ . They have a mailing list to keep you updated with events.
It's wierd to think that there were unknown people driving FD's around Ventura County. I see a few old ladys in the Ventura area all the time. Never saw one in Ojai though.
Old Oct 31, 2004 | 06:17 PM
spank1's Avatar
faster
There was no oil in eng the red dot light was on and no pressure I watched
them put the oil in after the car was pushed back to service bay.
Old Oct 31, 2004 | 06:52 PM
RotaryResurrection's Avatar
I've never seen an engine run for more than 10 seconds when it truly had no oil supply. There had to be at least a quart still in circulation. The thing would have locked dead up and spun bearings if it was absolutely out of oil. No way around that. IT would not have made it farther than being backed out of the bay the first time...
Old Oct 31, 2004 | 07:05 PM
spank1's Avatar
faster
I checked the dip stick myself and it showed no oil.
Old Oct 31, 2004 | 07:09 PM
afterburn27's Avatar
Lets Go Hokies!
I'm with Kevin, there had to be *some* oil in there or it wouldn't have run for more than a minute tops.
Old Oct 31, 2004 | 07:12 PM
KoiHoshi's Avatar
Yeah but a quart of oil? Still... Even if there was SOME oil and they forgot to put it in and turned it on, no way in hell I'd take it to a place like that again. Even if they didn't do any damage it's the fact that it sounds really negligent on their part.
Old Oct 31, 2004 | 07:20 PM
ROTARYFDTT's Avatar
Ding King
It is my understanding that even though the oil pan is drained during an oil change. There is still going to be oil in the oil cooler(s), oil cooler(s) lines, and other lines as well. Although I am not sure how much that equates too. But regardless, I'd try to get all that I could out of the situation, that’s absurd. I am sorry to hear that happened to you.
Old Oct 31, 2004 | 07:21 PM
Lets Go Hokies!
yeah, I'm not defending their stupidity, just stating that there had to be some oil left in the engine, at least enough for it to run for a few minutes without cooking itself
Old Oct 31, 2004 | 07:33 PM
adam c's Avatar
Cheap Bastard
Just one more reason NOT to have at turbo timer.
You should know better than to take your car to a Mazda dealer, especially for something like that. Do it yourself.
Old Oct 31, 2004 | 09:40 PM
fd0's Avatar
fd0
formerly chillin_rx7_guy
On the oil dipstick, if it goes from F to E, you've lost something around 1.4 quarts. I checked it on the service manual because me being the dummy, I forgot to check the oil level before taking my 250 mile trip!!! Doh!
Old Oct 31, 2004 | 10:37 PM
J.S.J's Avatar
I don't know why some guys seem to think the engine would not run without oil but it surely did. There was some left on the barring surfaces but none to be pumped to pressurize the barrings. Surely there is damage to the barring surfaces both in the engine and the turbos. If they expect you wait for a problem to surface there must be nuts. I would jump on them now and demand an engine. They are just hoping you will go away and if you have a problem 3 months from now they will shut you down. They screwed up, I would except an engine and nothing less. Knowing there could be substantial damage to an engine which is built on the edge from the factory as a true performance unit. Just my opinion 20 years dealership drive-ability specialist.
Old Nov 1, 2004 | 11:38 AM
I think it couldnt have run without oil, because I have personally seen engines that ran without oil. I was around 2 cars that ran out of oil, each one locked up within seconds.
ONe was an FC partscar I bought for 200 dollars, unflooded it and took it for a drive about 2 miles. Just then the oil buzzer went off, but I was in the middle of a bridge with no shoulder, so I had to continue to the other side. Before I even made it, about 15 seconds, all the oil dumped out and the engine quickly lost power and locked up. Turns out a DPO had replaced a leaking oil cooler hose with a garden hose.
Once was when a local guy rebuilt his own engine at my place. I let him do his own work and was there to help when he asked. HE puts the thing in and fires it up, revs to 3000rpm for a few seconds to clear it out...maybe 5 seconds later it just goes buuuurrrr-clunk. IT was locked solid then, not even a breaker bar would help. HE pulls it out and apart to find that he let the oilpump drive sprocket key slip out of place during install, so as soon as the pump loaded with oil it stopped spinning. Locked and spun the front rotor and main bearing. The engine did have assembly lube on all bearings, and this coating of oil is only good for a few seconds before it is dissipated and you have metal to metal contact.
Either there was oil in the car to some extent (Hell, I dont know, maybe one guy put in a quart or 2, and then left or forgot the rest) OR you have an engine with damaged bearings. Check your oil filter and oilpan for metal.
Old Nov 1, 2004 | 11:51 AM
DamonB's Avatar
If there was no oil circulating in the motor that thing would have seized within moments.
The low oil level light is just that, low oil level. Just because the light is on doesn't mean it is dry. If all they did was putter it around the parking lot and idle I bet all is fine. We all know it's no big deal for the stock oil pressure sender to read 0 psi.
If that motor truly had no oil in it it would have locked up way before you got in it. If a bearing was spun you would know it. Have the dealer right up a letter with signatures from the Service Manager and the owner that documents what happened.
Old Nov 1, 2004 | 11:54 AM
DamonB's Avatar
If there is no oil pressure to the bearings the engine will seize very quickly (see RotaryResurrection's post). A film of oil present isn't sufficient as it will quickly overheat and breakdown since it is not circulating. Even idle speed would destroy an engine with no oil pressure quickly, regardless of if the bearing surfaces were wet with oil.
Old Nov 1, 2004 | 01:09 PM
mad_7tist's Avatar
the thing is during an oil change you maybe drop out ~ 4 qt the engine dry capacity is about 5.5qt. when RR's car siezed it was actively pumping out oil so it ran dry. yes there is no doubt some extra wear and tear occured but they will say it was negligable as the car is still running. did it take 5,000 mi off the life of the engine? who knows. i would talk to another service advisor and see what they will do for you. new engine would be a good goal
Old Nov 1, 2004 | 01:39 PM
turbojeff's Avatar
Do it right, do it once
Great advice, send the oil out and have an analysis done. That will tell you what is really going on. Makes you a reasonable customer, base the issue/problem on facts not what you think may or may not have happened internally to the engine.
Jeff
Old Nov 1, 2004 | 02:45 PM
DaleClark's Avatar
RX-7 Bad Ass
Most places are insured against situations like this - if you need a new motor because of their negligence, their insurance should take care of you.
Dale
Old Nov 1, 2004 | 02:50 PM
rynberg's Avatar
The oil lines and filter (s) contain oil, even after fully draining the pan. You likely had between 0.5-1 quart of oil still in the system. I'm with the other guys, send the oil out for testing.
Old Nov 1, 2004 | 03:18 PM
Lets Go Hokies!
My new engine replacement plan: when engine is around 80,000 miles, have the oil changed frequently by Mazda dealers and jiffy-lubes. Motor should be blown by 5th oil change and new one covered under their insurance...
Old Nov 1, 2004 | 03:30 PM
J.S.J's Avatar
I will still state the fact is there was not enough oil to reach the pick up tube, hence no flow to barrings period. So you can decide for your-selfs if you think the barring surfaces were damaged. Sure they had some oil there but only enough to handle a few seconds. After that the heat build up becomes exponential. I could care less about what the shop would say in there defense. Remember its a dealership and they are better finding ways to remove accountability than repairing cars. I have has dozens of cars and trucks quickly brought to me after a major repair has been done which didn't fix the problem. Two come to mind, first a guys truck had a transmission installed , now it was a late 90s G.M. model. The bill was over 2,200.00 dollars and it needed a 10 dollar plug wire. The dealership ordered me to install a "used" wire as not to bring attention to the repair. The second is a Park avenue a 2000 model. The line tech installed a new timing chain etc because of a slow cranking speed. Well it needed a ground cleaned leading from the battery cable. Again I was "ordered" to repair it fast and keep it quiet. I refused but copied the repair orders and told the manager to back off or I would act against the dealership. I won out her but the dealer still nailed the costumers. I would act on the issue.
Old Nov 1, 2004 | 04:28 PM
DamonB's Avatar
The evidence in this case says that didn't happen. If there was no oil to the pickup tube that engine would have expired in a matter of seconds. I believe you that no oil to the bearings for any period of time is going to harm the bearings but this engine had oil to the bearings as the owner himself claimed it ran for a few minutes at least. If the oil pickup was actually starved that would have been impossible.
Old Nov 1, 2004 | 04:33 PM
turbojeff's Avatar
Get the oil tested, bottom line that test won't either there will be more metal in the oil or there won't be.
Old Nov 1, 2004 | 04:37 PM
spank1's Avatar
faster
The dealer wants me to bring the car back to drop the oil pan to check for any shavings
that would have come from the bearings. I would rather take it to a third party but they
are saying that they won't cover that and their insurance woun't cover any eng repair
unless they do it.
