NGK BUR7EQP Question
Old Oct 31, 2004 | 04:53 AM
andrewhacquoil's Avatar
Hey anyone know anything about these plugs?? I got a mechanic to change my plugs and he had never seen these plugs before. Are they anything special or can you use standard iridium plugs. The leading ones were the above yet the trailing are normal RE9B. Why have 2 different types?? The thread seems to be longer on the leading. Help please!!
Old Oct 31, 2004 | 07:36 AM
silver93's Avatar
The stock setup is to have two different types of plugs - leading plugs and trailing plugs. If you look on the rotor housing, there should be an "L" and a "T" to help, so you don't get confused when installing.
anyway, that's standard. a lot of people, myself included, run NGK BUR9EQP in all 4 holes. You can search to learn more about hotter and colder plugs,etc...
bottom line, NGKs are generally considered the best plugs for the FD.
Old Oct 31, 2004 | 09:57 AM
Rotarded's Avatar
"Challenged" since 1993
silver93 is correct, and I run all 9s as well.
Irridium plugs are an un-necessary expense. The platinum plugs are all you need. You will foul both types plugs at relatively equal rate and the platinums are much less expensive.
As far ar the thread seeming longer on the leading, the trailing plugs are recessed into the housing making them look shorter when installed.
Mike
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
