Help! No ODO
Old Oct 31, 2004 | 03:16 AM
Exclamation Help! No ODO
I'm blank. where did it go or where do I look for clues to why my odometer/ trip dosn't work. Ilumination works with lights but no numbers. Any suggestions?
Old Oct 31, 2004 | 07:14 AM
KINETIK_FD3S's Avatar
almost done
same thing happened to me but this was when i was switching gauge clusters back and forth , it was a harness plug check that none of the pins on the connectors are flat.
Old Oct 31, 2004 | 09:40 AM
DamonB's Avatar
The odometer has it's own light bulb behind it. If this bulb burns out you'll think the odometer quit.
Shine a flashlight onto the odometer while the key is on. If you can barely make out the dimly lit numbers you have a blown bulb or a loose connection to the bulb. If you see absolutely nothing while the light shines on it then I would inspect the odometer itself.
alphawolff
Nov 17, 2015 05:57 PM
jacobcartmill
May 19, 2007 04:44 PM
CrispyRX7
Nov 18, 2002 12:17 PM
