tranny stuck to engine
Old Oct 30, 2004 | 11:25 AM
rextacy's Avatar
I bought a long block with a tranny attached, and i am trying to pull the tranny off, and it gets about 4 inches then stops. it is a manual tranny.
the tranny is complettely unbolted from the engine, i just cant get it more than 4 inches away from the engine. The tranny is able to spin around, jerking and pulling seem to not help any.
I am working on it right now, quick replies or ideas would be appreciated
Old Oct 30, 2004 | 11:29 AM
BigIslandSevens's Avatar
look in the bottom inspection hole and you will see a "ring" that holds the throw- out bearing in place. This needs to be seperated fromthe T/o bearing. take a screw driver and pry the collar and t/o bearing apart. This should solve your issue
ijneb's Avatar
FOR SALE
Take a long screw driver and put it between the throw out bearing and the pressure plate, all it takes is spin the screw drivera half turn to get the T.O. bearing to seperate enough to seperate. anymore questions you can get me on aim (ijneb)
Old Oct 30, 2004 | 11:37 AM
Wargasm's Avatar
Weird Cat Man
Download and watch my vid if you have problems with getting the clutch unhooked:
http://www.zeroglabs.com/rx7/pullclutch.htm
Old Oct 30, 2004 | 11:46 AM
rextacy's Avatar
awesome thanks guys i will go try it out
Old Oct 30, 2004 | 12:02 PM
rextacy's Avatar
oh yeah you guys rock..
once i pushed that clip in it came right out.. i have done 20+ tranny removals on dsms AWD and FWD, and never had a problem at all.
I guess i am officially a newb
THANKS AGAIN MUCH APPRECIATED
cristoDathird
28
May 30, 2019 08:47 PM
thatfbtho
13
Aug 29, 2015 10:51 AM
sYnth.
Aug 19, 2015 06:27 PM
Wicked93gs
Aug 17, 2015 12:14 PM
