Need a Clutch for Drag Racing.
Old Oct 28, 2004 | 10:22 PM
modrx7's Avatar
Well, My car is in the final stages of getting done, and once I go through the break in of the engine, I will need a new clutch. Cause I am sure the street/strip ACT will not hold. My car should be somewhere around 500rwhp as for torque I am not sure, but I would hope for around 400rwtq. This being said, I need a clutch that will hold this at the minimum. Cause, I know I will want to push the car harder.
I was lookin into this clutch http://www.rx7store.net/index.asp?Pa...ROD&ProdID=759
or this one
http://www.rx7store.net/index.asp?Pa...ROD&ProdID=763
The spec seems alot more reasonable pricewise than the Exedy.
Thanks for your suggestions
Edan
Old Oct 29, 2004 | 12:43 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
is this for FD or FC? I can get you an OS giken twin plate clutch. they will hold well over 400lb tq and will suit your needs. They come with lightweight flywheel too. nothing extreme, just lighter than stock...lemme know
neil
Old Oct 29, 2004 | 06:58 PM
modrx7's Avatar
This is for an 93 FD.
Old Feb 25, 2005 | 11:23 AM
sevenin7's Avatar
As i know many racers use the stock flywheel with ACT 6 puck extreme , or exedy single or clutchmasters fx 500 !
Is really one of this the best set-up for dragracing , for an FD with 500rwhp ?
Who has experience about this ?
Old Feb 25, 2005 | 05:07 PM
LETHAL RX7's Avatar
Hey MOD i have an EXEDY twin plate for sale..its only got 500 miles on it. PM if your interested..
Greg
Old Feb 27, 2005 | 07:12 AM
sevenin7's Avatar
Who knows if the pressure plate of extreme 6 puck kit is 2600lbs ?
Old Feb 28, 2005 | 02:08 AM
Infini IV's Avatar
Microtech Tuning!
I would go with the Exedy Twin Plate if you want to be sure it will hold the power. It should also be a little easier to work with in traffic.
Old Feb 28, 2005 | 06:33 AM
sevenin7's Avatar
Exedy Twin its a very good clutch kit , but i would like to use the stock flywheel .
This is my problem .
Old Mar 8, 2005 | 02:17 PM
coldy13's Avatar
Yeah, shutup kid.
http://www.southbendclutch.com/ Call them, tell them what you need the clutch for, and they should have a clutch for you. I'm running one from them in my turbo FB. It's a ceramic 6 puck, sprung hub, double sprung pressure plate, the pedal is as light as stock and it grips HARD.
Old Mar 8, 2005 | 09:37 PM
LETHAL RX7's Avatar
hey edan i still have it.... im actually waiting for you to email me back
Old Mar 10, 2005 | 08:30 AM
arghx's Avatar
rotorhead
You can't go wrong with ACT. Get a 6 or 4 puck with the extreme pressure plate.
Snoopy FD
Oct 13, 2016 06:12 AM
kryan9
Sep 15, 2015 10:11 PM
risingsunroof82
Sep 9, 2015 08:06 PM
