Power FC Does your Heat hazard lite come on?
Old Oct 26, 2004 | 07:57 PM
badddrx7's Avatar
All Spooled Up
When you simply turn the key to the ON position with the PFC ? Or does it come on after the car is running IF a problem exists ? I removed my Heat hazard switch a long time ago and now that I have a PFC I want a simple lite to tell me when somethign is wrong. I used Ign 12V on one side of a 1.4 watt bulb and hooked to ground side up to ECU connector 2I which is a Orange/Blue wire ( per the manual )
Just want to make sure I have the connection right.
Tom
Old Oct 27, 2004 | 03:12 PM
TailHappy's Avatar
Addicted to Track
It comes on when you turn the switch on, so that you can make sure the bulb works. As soon as you start the car, it should go off.
I may be misunderstanding your message, but I'm quite sure the overheat light won't illuminate for you because of the PFC, like it indicates that it should. Using the datalogit I artificially set my knock and inj duty thresholds really low to see if any lights would come on, and they don't. I've never seen any proof that this feature ever worked with our version of the PFC.....
Old Oct 27, 2004 | 03:52 PM
badddrx7's Avatar
All Spooled Up
I do not believe it does. I have the PFC installed, car runs. The overheat light never lites up....with key on, with engine running. Heck I even disconnected the Air temp sensor with the engine running and the lite never came on. I did see the sensor log on the commander show that the sensor had a problem.
Am I right- the overheat lite never comes on with our version ?
Tom
Old Oct 27, 2004 | 04:36 PM
allenhah's Avatar
Dirty
From my understanding, the light is supposed to light up when you first turn key on and it stays lit until you start the engine, at which point the light turns off if there are no problems. From there, the light is supposed to stay off unless there is an error with one of the sensors or one of the thresholds are passed. If a sensor's busted or giving off bad readings, it will light up, and you should be able to see which sensor it is in the "sensor/switch" screen on the Commander. If you exceed the boost level or the knock sensor limit, it's supposed to flash, but I have yet to see that happen either.
Old Oct 27, 2004 | 05:50 PM
badddrx7's Avatar
All Spooled Up
Thanks Allenhah....so let's recap, so far we all agree that the little exhaust overheat light does NOT light up for anyone on this thread so far. Correct ?
Reason I am asking is, I do not want to connect that circuit back up if it don't work. And I have it temporary right now and it ain't workin.
Tom
Old Oct 27, 2004 | 06:06 PM
allenhah's Avatar
Dirty
Negative. My light DOES light up with key on and then turns off when the engine is started. It's supposed to work.
Old Oct 27, 2004 | 08:02 PM
badddrx7's Avatar
All Spooled Up
Is your car and PFC issued in the USA or Japan ?
Tom
Old Oct 28, 2004 | 12:40 AM
allenhah's Avatar
Dirty
I'm not quite sure. I bought the unit from a forum member. It's definitely the new version (5.4, I think?), and most of the text is in English. The "Yes/No" in the setup screen is still in Japanese.
Nevertheless, I would imagine that mine is a US spec version...
Old Oct 28, 2004 | 12:28 PM
OC94Rx7's Avatar
_________________________
Tom
I have a '94 US model FD with a US version PFC ....
My light comes on when key is turned on and goes off when started, just like TailHappy and Allenhah. I have never seen the light come on for anyother reason, perhaps TailHappy is correct the function may not work for our version? I can't say for sure.
Old Oct 28, 2004 | 06:12 PM
badddrx7's Avatar
All Spooled Up
Once again - other than key on/off.....so far we all agree that the little exhaust overheat light does NOT light up for anyone on this thread so far. Correct ?
Tom
Old Oct 29, 2004 | 01:15 PM
TailHappy's Avatar
Addicted to Track
Exactly. If it doesn't come on when you turn your key on, then the bulb's out. But other than that, I've never seen it come on for any reason whatsoever, including the racetrack.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Sh00bs
Oct 1, 2015 11:57 PM
