Mini die grinder for porting?
Old Oct 22, 2004 | 07:27 PM
Dan H's Avatar
Zoom Zoom Boom!
Do mini die grinders have enough power to do standard porting work on the irons? Or should I get a standard one with more power?
The main reaons I want a mini die grinder is because they're easier to be precise with when porting, uses less cfm (less interrupting when my compressor recharges), and its a bit cheaper ($25-30.)
If it matters, I plan on using carbide bits to do the port work.
Old Oct 22, 2004 | 07:29 PM
razorback's Avatar
You've Been Punk'd
get a dremel. thats what i used and it works good.
Old Oct 22, 2004 | 08:04 PM
Dan H's Avatar
Zoom Zoom Boom!
I've always thought die grinder > Dremel ??
I have a mid-end Dremel but it likes to halt when I really start to grind on some hard stuff. and then makes some nasty rough edges. And from what I've seen, a die grinder just shrugs it off and seems to have so much more power and speed to make smoother ports.
Old Oct 22, 2004 | 11:04 PM
I hate dremels, I've burned out 2 of them.
Old Oct 22, 2004 | 11:07 PM
razorback's Avatar
You've Been Punk'd
i didtn have any problems. maybe its the bits that were being used? i know bdc uses only dremels on his porting.
Old Oct 23, 2004 | 02:47 AM
88IntegraLS's Avatar
Displacement > Boost
I've always used my dremel and the cheap stones to do my porting. I finish them up with sanding drums and a polishing drum. My latest efforts are in a thread on Nopistons.com, all done with a dremel. I prefer the dremel because it is lighter and easier to control.
Old Oct 23, 2004 | 04:22 PM
Dan H's Avatar
Zoom Zoom Boom!
Well, I bought the mini die grinder. If it sucks, then no big deal. It was only $20.
Old Oct 24, 2004 | 02:05 AM
Jeff20B's Avatar
Lapping = Fapping
Dremel with cut-off disks, a couple stones and sanding drums. It takes a bit longer than an air die grinder, but it's cheap, easier to control, less noise, less costly to operate (small electric motor vs electric air compressor motor) and dare I say less messy?
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
GraysGarage
18
Feb 22, 2018 11:54 AM
josef 91 vert
14
Sep 17, 2015 09:22 PM
Neo
Canadian Forum
Sep 14, 2015 09:09 AM
