Microtech can i remove it?
Old Oct 20, 2004 | 11:51 PM
FC_mania's Avatar
can i remove it?
i would like to know can i remove the charcoal canister? (where do i wire those lines then?) , BAC valve ( again do i need to plug any holes?) and all the misc vaccuum device on the T/B.
thanks a lot
im goin microtech LT8s
Old Oct 20, 2004 | 11:56 PM
Infini IV's Avatar
Microtech Tuning!
Yes, but why would you want to?
Well actually, I did because it was in the way when I was removing the ABS pump.
One line comes from the vent at the oil-fill tube (or was it the vent at the block?). The other is to vent the fumes from the fuel pump. It doesn't really matter if you remove it or not.
BAC valve you can remove, and get a block-off plate.
Old Oct 21, 2004 | 02:12 PM
FC_mania's Avatar
ok thanks... what about the line from the BAC? valve
Erosangel
Sep 18, 2015 04:06 PM
Steelwheelz
Sep 15, 2015 03:22 PM
