F18x8 offset 35 & R18x9 offset 38 work?
Old Oct 17, 2004 | 10:28 PM
promax's Avatar
I am wondering will the above size work on my FD, I have stock R1 suspension and H&R springs. I'm done some serach in the forum, people usually running 40+ offset for that kind of size... Just wondering if it will work or not. If so, what size of the tires should I run?
Thanks
Old Oct 17, 2004 | 11:03 PM
SpeedKing's Avatar
Power Trippin'
No. There will be more rubbing going on than in a massage parlor.
Old Oct 18, 2004 | 05:34 PM
Rx7@Rocketship.com's Avatar
They should work fine if you choose the right tire for the front.
I had 17x8x32 F and 17x9x38 rear with 245/40 or 225/45 Fronts and 255/40 rears and they were ok.
Compare overall tire/wheel sizing to what I gave you here and you'll be ok, unless you take pleasure in cranking the steeering wheel full lock and drive up steep entrances.
David
Old Oct 18, 2004 | 10:10 PM
promax's Avatar
so what should be the proper offset for this size?? 40 or 45?? I guess 225/40/18 front and 255/35/18 Rear should be fine for these rim, right?
Old Oct 18, 2004 | 10:32 PM
SpeedKing's Avatar
Power Trippin'
promax: Check out this thread - https://www.rx7club.com/suspension-wheels-tires-brakes-20/fawked-up-my-fender-337757/
"David Kim" was running 18x8 wheels up front, +40 offset w/ 235/40-18 and Bilstein HDs and H&R springs and pulled his front fender out. The difference between 225/40-18 and 235/40-18 is only ~0.3", however, the wheels you're considering have an even lower offset of +35. No offense to "Rx7@Rocketship.com", and granted, every car is different, but IMO, it's too close to call. I'd err on the side of caution and look for wheels with a higher offset.
Old Oct 18, 2004 | 10:35 PM
Mahjik's Avatar
Mr. Links
With what suspension setup?
Old Oct 19, 2004 | 05:34 PM
I'll focus on the front setup as this seems to be the most critical.
225/45 with Racing beat springs and R1 shocks
245/40 with 600lb coilovers and Koni
Both with a 17"x8"x32mm SSR Integral.
David
Old Oct 19, 2004 | 06:29 PM
Simply to add to my post above...
an 8 inch rim with a 32mm offset is no worse than a 9 inch rim with a 44 or 45mm offset, and many are using that fitment with no issues.
To emphasize the situation further, an 8 inch rim with a 32mm offset still has the wheel edge favorably sitting further inwards by more than a quarter inch when compared to a 10 inch wheel with 50mm, another relatively trouble free well known fitment. Granted, at this point there is always a way of catching a lip if someone really intended it.
David
Old Oct 20, 2004 | 07:22 PM
oakridgerx7's Avatar
im running 18x8.5 fronts, with 18x9.5 rears(both 35mm offset) with racing beat springs, and tokico illumna shocks. I only experience minor rubbing while turning sharp and going up inclines(like pulling into a steep driveway. tires are 235-40 18, and 275-35-18
Old Oct 21, 2004 | 12:57 PM
p l a y j a y's Avatar
I'm curious about this set-up, do you have any pictures?
Old Oct 24, 2004 | 04:07 PM
here is a pic of my car with 35mm offset
Old Oct 24, 2004 | 05:23 PM
rotoboy661's Avatar
fr: 18 +40 rr: 18 +38
Old Oct 24, 2004 | 08:01 PM
now that is one badass FD! those wheels look great! makes me miss my black one
BTW. it looks like there is a tree growing out of the center of your hood! LOL
Old Oct 26, 2004 | 09:44 AM
rotoboy661's Avatar
thanx
MILOS7
Aug 19, 2015 07:25 AM
