Power FC Knock readings shoots up for no reason!
Old Oct 17, 2004 | 05:28 PM
BATMAN's Avatar
After chaning my oil this morning I fired up the car for a drive.
As I left my driveway I looked at the Commander and it was reading 80 on the knock without boost.
That black bar increases when I rev up the engine in neutral to about 4k RPMs.
So I decide to gingerly drive the car and cruise on the freeway.
During this time I would slightly boost the car and knock would drop down a little.
Where should I start on this?
I just don't get it.
Old Oct 17, 2004 | 05:36 PM
ejmack1's Avatar
Lawn Ornament
short in the wire.... oil on the connector?
Old Oct 17, 2004 | 06:56 PM
Tim Benton's Avatar
FD title holder since 94
never did it before? My car will have a higher knock value until it gets warmed up, then its smooth as butter.
Tim
Old Oct 17, 2004 | 07:12 PM
BATMAN's Avatar
It has, but ranges from 10 - 20, not 80 with partial boost.
I did spill some oil as I was filling it up (darn strut bar's fault). Perhaps that might have something to do with the knock readings going cuckoo.
Old Oct 17, 2004 | 09:54 PM
Tim Benton's Avatar
have you recently filled up the tank? Bad gas...just ideas.
Tim
Old Oct 18, 2004 | 10:58 AM
allenhah's Avatar
Dirty
I don't know if this will help, but I was talking to Rick the other day about the knock readings, and said once a customer's car was doing that, and they eventually traced it down to a bad air pump! Once they disconnected the pump, knock readings were totally normal again...
Worth a shot, I suppose...I could see how a bad pump (of any sort really) could replicate knock sounds in the engine bay...
Old Oct 18, 2004 | 11:05 AM
BATMAN's Avatar
nope, I've already factored that out since I have been driving on this tank for a week already without any problems.
Old Oct 18, 2004 | 11:06 AM
BATMAN's Avatar
My airpump does have alot of miles............ 250k~
Old Oct 18, 2004 | 11:33 AM
patfat's Avatar
Track junkie
Mine has 60K miles on it. Want to buy it?
Old Oct 18, 2004 | 11:41 AM
allenhah's Avatar
Dirty
Well before you go and buy a new airpump, try disconnecting it electrically first (should be a simple connector) and see if the knock goes away.
Old Oct 18, 2004 | 02:02 PM
Tim Benton's Avatar
is the sensor torqued in to spec, although that damn thing is a bitch to get to with that oil line in the way.
Tim
Th0m4s
Feb 26, 2019 02:04 AM
