AEM c2di help
Old Oct 17, 2004 | 11:51 AM
carx7's Avatar
AEM c2di help
I am trying to get my C2di working and have a quick question. I have read all the recent complaints about the unit so I am aware of the quality issues.
I am not getting spark when trying to start. I belive it's b/c the unit is never turning on. I wanted to verify if the red LED does infact light up when the car is powered? I did verify the constant power and ground wires to the unit via a continuity check. I did the same with switched 12V.... but I get no LED.
Is this normal, or is mine broken before I ever turned it on?
-chris
Old Oct 17, 2004 | 11:55 AM
carx7's Avatar
NM, I just realized that the LED is to indicate that it fired a coil... My bad.
-Chris
Old Oct 17, 2004 | 10:54 PM
rfreeman27's Avatar
check your fuse...i blew mine right away because i installed it incorrectly. When i fixed the problem i was sitting there scratchign my head...took a second to realize what i had done..
Logan Reinisch
44
Sep 17, 2018 12:20 PM
eplusz
15
Oct 7, 2015 04:04 PM
