custom sub boxes? location etc
Old Oct 14, 2004 | 11:43 AM
djadict_d's Avatar
i have two 12 infinity dvc and a 1200 watt amp and i have noticed that the storage compartments are basically hollow has anyone seen or has a box made into those bins? if you have i would like to se4e them or if anyone has any other ideas i would like to know pictures are a plus i need to show the installerto fabricate me something.... thanks
Djadict_d
Old Oct 14, 2004 | 12:06 PM
hypothermix79's Avatar
i'm making a fiberglass box out of mine.
you should check out cardomain and other related sights.
here a link where some guy redid his whole hatch area. The box I'm making is simular to his, i'm not going to do the whole hatch area like that though.
http://www.cardomain.com/memberpage/315099
by the way this should probably be listed under the audio forum and may get moved
Old Oct 14, 2004 | 12:33 PM
West TX RX-7's Avatar
Da Monee Pit
First picture is of the original setup, last 3 are the second configuration. Both used the bins. They were fiberglassed inside to seal them up then filled with sound deadening Cotton looking stuff to get a neutral sound.
Old Oct 14, 2004 | 12:42 PM
marshp's Avatar
Registered Rx7 Owner
this is my setup.. really easy to make and sounds really good, i have the amp in one of the storage compartments locked shut so no one can steal (hopefully)
but i think my setup is good, really heavy also, so makes it safer<br>
Old Oct 14, 2004 | 12:50 PM
West TX I really like the enclosure on the first one. You did a good job on all the fabrication for the whole thing.
Old Oct 14, 2004 | 12:52 PM
uRizen's Avatar
XBL** Ownicus
Wow, those are pretty cool setups, I like the deep cell battery nestled in there.
I'm using my spare tire area since my spare is worthless anyways. I'm only putting in one 10" though, which should work great for a car as small as ours.
Old Oct 14, 2004 | 12:54 PM
uRizen's Avatar
XBL** Ownicus
Hey, that's another thing I forgot to ask about. Where do those triangular speaker covers in the rear come from? My 87 came with these boring old covers.
Old Oct 14, 2004 | 01:36 PM
djadict_d's Avatar
theses are awesome i really like the first one with a little modifications of course butthen i also like the second one because you still getto keep your storage bins, butyeah these are very cool if anyone has any other pics i would like to see them...
Thanks Guys
Djadict_d
Old Oct 15, 2004 | 09:29 PM
BlueSteel's Avatar
No destination.
great work guys, i really like both those enclousres. Workin on my set up this weekend, 4 10" MA Audio subs in the back (along with my exisiting 6 speaker pioneer) is it cool to post pics on this thread when its done?
Old Oct 15, 2004 | 11:13 PM
Da Monee Pit
Yep post up and also in the 2nd gen section.
BTW I changed configs cause I needed access to the fuel pump which I could not get to with the first setup. Thesecond one I can remove the black inset panel and get to it.
Old Oct 18, 2004 | 01:54 PM
djadict_d's Avatar
post away man i am lookin forward to seeing it
