Will 4 lug pattern wheels for 86-88 fit 1st gen GSL-SE?
Old Oct 13, 2004 | 11:03 PM
pjr's Avatar
pjr
Mr May 2011
My question is whether a 4 lug pattern wheel for a 86-88 2nd gen fit a 1st gen GSL-SE? I know they won't fit other 1st gens.... and I know that most of the 2nd gens were 5 lug... but are the 4 lugs the same pattern?
Old Oct 14, 2004 | 12:31 AM
wwilliam54's Avatar
it WILL run
yeah
Old Oct 14, 2004 | 12:41 AM
ARD T2's Avatar
There is
4x110, non SE model First Gen.
4x114.3 GSL-SE and FC SE.
5x114.3 thereafter
Hope that helps,
Rishie
Old Oct 14, 2004 | 09:19 PM
pjr's Avatar
pjr
Mr May 2011
That what I thought, but needed to be sure...Thanks!!
Old Oct 18, 2004 | 07:01 PM
Psycho3's Avatar
is the base model 87 rx7 also 4x114.3? thanks
Old Nov 14, 2004 | 06:58 PM
dblboinger's Avatar
ARD T2... You are sure about the spacing info you mentioned? I'm only asking so I don't make a mistake. I own an '83 GSL but recently found the frame is bent slightly, but repairable. I have an opportunity to pickup a 84 GSL-SE and/or an 85 GSL-SE for less than it would cost to repair my 83 GSL.
So far I have found the following advantages of the GSL-SE over the GSL....
1) The GSL-SE has power steering the GSL does not
2) The GSL-SE has the fuel injected 13B, the GSL does not
I have had a devil of a time finding rims for the GSL, but if your information is correct there are many more options for the GSL-SE. Any toher advantages anyone out there may know of???
Old Nov 15, 2004 | 03:04 PM
ARD T2's Avatar
The GSL-SE with the 13B is a 4x114.3 which will match any OE FC 4 lug boltpattern. Since you are 83 you have the 110 pcd. Get the SE models, rims will be a lot easier to find.
craaaazzy
Comments and Suggestions Archive
Aug 21, 2015 02:00 PM
Marty RE
Aug 13, 2015 11:19 AM
jza80
Aug 12, 2015 11:10 PM
