Cutting Off a rear 1/4 panel
Old Oct 12, 2004 | 08:35 PM
c00lduke's Avatar
I have a buddy that wants me to help him with this and he doesnt seem to have a good way of doing it so i was wondering how some of you guys would go about it and how it is supposed to be done?
Thanks
~Luke
Old Oct 12, 2004 | 08:53 PM
scheistermeister's Avatar
Throbbing Member
air chisle, sawzal
Old Oct 12, 2004 | 10:17 PM
sawzal..bwahahahaha. Or just a cutting wheel.
Old Oct 12, 2004 | 10:49 PM
darkside7's Avatar
Plazma Cutter!!!!!!! :-)
Old Oct 13, 2004 | 07:27 PM
unvmyrx7's Avatar
drill out all the spot welds, cut the pillar and the rocker panel using a cut off wheel. do not use a sawzall or air chisel.
Old Oct 13, 2004 | 11:00 PM
c00lduke's Avatar
Any hints on how to find these spot welds?. it seems to be connected all the way around so i thought i would have to just cut it off. if i drill all these out and cut at the side skirt and b pillar is will come off?
Old Oct 14, 2004 | 08:51 AM
unvmyrx7's Avatar
use a sanding disc to remove the seam sealer and paint from where the quarter panel skin bonds to the wheel welds, under the hatch, around the tail light, etc.
Old Oct 14, 2004 | 09:51 PM
1234rotor's Avatar
GearHeadMoFo
I need to replace the 1/4 on my Fd as well. Do any of you work at a body shop for a living??
I was already planning on doing the spot-weld drill, and cut-off at the b-pillar braze.
Any more info??
Or links on how to do body repair the right way??
Do most body shops have a way to do the brazing??
Old Oct 15, 2004 | 01:42 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
Be extreamly careful when using heat on body pannels. The sheetmetal on cars is not thick enough like it once was to stand up to high heat. Only spot welds and mig welds no longer than 1" at a time should be used.
Old Oct 15, 2004 | 04:38 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Im doing a similar project tommorow, only this car is desposable Long live the Geo Metro XFI!
I talked to a few body shop people and they all gave me the same advice when rewelding on my new 1/4 panel.
Tack it up, and then move down 2 inches, tack it again, move down tack etc etc untill you go all the way around. Then go back to the first tack, and tack directly next to it, then move to the next tack, directly next to it again, etc until you go all the way around. Repeat this till you have a solid weld all the way around
If you run a long bead the metal will expand and shrink, he explained he's seen attempts that have left 2"+ waves in the new metal, not cheap to fix
Ill take pics of my geo as i go, see how it works out. Illl be using a 110 Mig hobby welder, supptoto weld upto 3/16's a single pass, well see how it goes
-Jacob
Old Oct 15, 2004 | 07:38 PM
unvmyrx7's Avatar
Any more info??
i worked in a body shop for 3 years, i'm a cable guy now
most shops don't do brazing, they spot weld quarter panel under the pillar where the joint is going to be made, then you grind down the welds and apply a thin coat of body filler
Old Oct 17, 2004 | 11:42 PM
Skiles2070's Avatar
perrty lil rotory
ok... how would you do this: I have seen replacement rear 1/4 panels, 30 mm. wider, but they are made out of fiberglass, I do not want them to be rivited on and just put over the original sheet metal, but how else could you do it? its on an FC. aitracing.com
Old Oct 18, 2004 | 10:08 AM
unvmyrx7's Avatar
those fiberglass rear quarter panels have to be rivited or glued on. you can use dura mix or other high strenght adhesives. you cannot cut the oem steel panels off and install a fiberglass fender on a unibody car. the frame will flex and crack where you join the fiberglass to the pillar or rocker panel.
you can fill expanding foam under the fiberglass quarterpanel to make it more solid, these panels are thin and designed to me molded on using reinforced fiberglass body filler
Monsterbox
Jul 29, 2022 10:48 PM
