Power FC 1600cc injector settings in power fc
Old Nov 28, 2001 | 07:30 AM
Dragon's Avatar
20B N/A Wide Body FC3S
Question 1600cc injector settings in power fc
what injector settings are you running with your 1600cc bosch injetors if you have them installed?
This is what I'm running now...
Fr-Pr 64.5% +.04 ms
Fr-Sc +0.08 ms
Rr-Pr 64.5% +.04 ms
Rr-Sc +0.08 ms
Q-Pr 850cc
Q-Sc 1500cc
Old Nov 28, 2001 | 07:43 AM
Are 1600cc Bosch Injectors a direct fit for the secondrys and can the Power FC drive them as I was told that the Power FC can handle upto 1300cc ONLY ???
Old Nov 28, 2001 | 07:57 AM
Dragon's Avatar
You can set it up for up to a 1500cc injector. You can get the fuel rail from K2RD and you need to put a 10ohm resistor on each of the power wires to the injectors...
then you'll have to tweak hte fuel map from when the 1600's start firing on up, I didn't really have to change mine much since I was running a little lean threw the top end anyway...
Old Nov 28, 2001 | 09:30 AM
Thanks Dragon,
Do I need a Greddy Rebic to run the injectors or are they controlled by the Power FC.
What is hte ?
Old Nov 28, 2001 | 06:44 PM
Dragon's Avatar
They replace the stock 850's and the fuel rail and are controlled by the power fc...
hte is "the" typed too fast....
Old Nov 29, 2001 | 07:53 AM
Dragon thanks for your reply.
regards,
Colin
Old Dec 9, 2001 | 11:37 PM
Dragon's Avatar
I'm running 2 x 850's and 2 x 1,600's....
Old Dec 10, 2001 | 04:01 PM
Dragon's Avatar
no 1320's here on okinawa, just a 150meter 1/9th mile. I haven't done a power check since I installed the injectors...
Old Dec 11, 2001 | 04:52 AM
Dragon's Avatar
Originally posted by wankawankel
I had the 850/1600 inj combo previously. My car ran extremely rich, were my plugs would foul out every month. Did I mention it smelled like a gas station in and out of my car, even when driving. And my exhaust turned my bumper black. Does your car have these symptoms? If not, how well does your car run on the street and the track. Who tuned your Apexi PFC?
I run the stock base map... by tunning the program and playing with the pin and rpm %adj. settings I've got it running pretty damn nice.. I'ts a little rich and my bumper does turn black, but I'm running a pretty large side and exaust port. My plugs never foul out, but I'm running a HKS twin power with stock 9 plugs for leading and trailing... The car runs good on the street with good low rpm tork on the track I keep shattering 3 and 5th gear syncros and locking collars when going in to 3rd.. she's quite happy in 1st and 2nd though...
