Power FC occasional blue smoke, and pfc map?
Old Nov 27, 2001 | 11:23 PM
single o 7's Avatar
Ok, here I go... I have a 93 r1, and the engine only has 7,500 miles on it, as well as the turbo. Here are the mods- Single garett turbo, hks blowoff valve, autometer boost and air fuel ratio guages,greddy elbow, front mount intercooler, underdrive pulleys, street ported motor, hks super dragger exhaust. And thats all the main mods I can think of. And yes I know I need larger injectors, and a power fc... Which brings up the question, does anyone have a map close to this??? with added 850cc injectors on both primaries and secondaries?
But I am seeing blue smoke which smells like gas when car is running lean or rich, according to the guages. definately not sweet... no coolant leaks here. And definately smells like fuel. Now I hope to hear replies from you guys like, get a power fc or larger injectors, but is any other ideas... tell me !!!!!!! thanks in advance Brian... Single-0-seven
Old Nov 28, 2001 | 08:50 AM
cewrx7r1's Avatar
Eye In The Sky
People,
When listing mods for info about fuel or timing mapping, only list engine mods that affect the intake and exhaust systems and fuel. In other words, things that affect air flow through the engine plus fuel injection.
We assume that your fuel pump and pressure regulator will be stock in functionality and adequate. Only list them if they do not function normal like a rising rate regulator. Stock Mazda fuel pressure is 38psi at 0 boost. Above 0psi boost it is 38 + boost pressure.
Things like underdrive pulleys, ignition amps, bovs, etc. are totally irrevalent.
Thank You,
Chuck
Old Nov 29, 2001 | 11:08 PM
single o 7's Avatar
sorry
I am new to this forum, and just needed advice. I listed some of the other parts, because I am looking for the power fc map as well, and not sure what requirements are for the maps. I did find out however that under full throttle, I am achieving 15 pounds of boost (not good !!) Fortunately I drive the car slow, and have only done this once, thank god I have not detinated. So any advice is appreciated
24seven_dada
20
Nov 10, 2018 12:03 PM
Ian_D
Oct 14, 2015 12:31 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
