Greddy knob
Old Sep 22, 2004 | 10:51 PM
moktan_fdtt's Avatar
Exclamation Greddy ****
I just got my new Greddy counter weight shift ****. I love it so far, but since the **** is a lot shorter than stock, it leaves a gap between the boot and the ****.
What should I do?
Cut it?
I really don't have money for a short shifter right now.
Any suggestions?
Old Sep 22, 2004 | 11:02 PM
bump
Old Sep 22, 2004 | 11:38 PM
bump again
Old Sep 23, 2004 | 03:01 PM
tobecontinued's Avatar
Ghetto fix- wrap some electrical tape/ heat shrink tubing around the exposed part of the shifter.
Better fix- Get some vinyl/ leather and make a "extension" to your shift boot
Old Sep 24, 2004 | 03:08 PM
DaleClark's Avatar
RX-7 Bad Ass
I'm gonna be doing a full writeup on this at some point...
Had the same problem with my FC - the shift **** sat way up high. First off, measure and find out how much lower you want to go - on the FC I think I dropped it down an inch.
Remove the **** and hacksaw an inch off the shift lever from the top. Get a tap/die set and get the proper sized die to tap threads further down the shaft. The **** will then screw right in where you want it to go. Turned out awesome on the FC, and didn't take much work at all to accomplish.
Dale
Old Sep 24, 2004 | 04:07 PM
FDNewbie's Avatar
Sponsor
Is the lever shorter on shortshifters than on the stock shifter??
Old Sep 25, 2004 | 01:23 AM
KaiFD3S's Avatar
SINFUL7
like I said take the center console out ...with the shifter exposed wrap electrical tape around it so the leather that covers the shifter will sit on it therefore lifting the boot next to the shift ****...
Old Sep 26, 2004 | 12:27 AM
Daniel577h's Avatar
danny rocks
cut it off with drummel tool, i did it on my old bmw worked good.
