Fuel filter replacement question
Old Sep 16, 2004 | 12:03 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
I am going to replace my fuel filter soon. I read the 1300cc article and I'll be able to handle the task. My one question is about those metal "clips" that hold the hoses to the filter. Can those be reused after I take them off? If not would any auto parts store have replacements?
Old Sep 16, 2004 | 12:06 PM
jon88se's Avatar
Eat, sleep, work, mod.
Yes, you can reuse them.
Old Sep 16, 2004 | 02:33 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Prepare to get gasoline all over yourself. If the filter has never been changed expect it to be a PITA to remove. I use pliars and a clamping/twisting method.
Old Sep 16, 2004 | 02:49 PM
DerangedHermit's Avatar
I prefer to:
A: double clamp all my fuel lines
B: use 1 spring clip and 1 screw clip
Old Sep 16, 2004 | 02:54 PM
Pinfield357's Avatar
you wont want to use conventional screw type clamps use the band type clamps that are ment for fuel injection
the old screw type clamps tend to cut the hose a little and with the high preasures of fuel injection that can cause problems
Old Sep 16, 2004 | 03:13 PM
Is it necessary to ruin my dreams?
Old Sep 16, 2004 | 04:39 PM
beefhole's Avatar
I will have to look for some/purchase band clamps then as I have the regular screw ones.
Old Sep 16, 2004 | 05:42 PM
Fijensen's Avatar
It is much easier if you take the hoses loose on the ends away from the filter. After you have it out, then get the hoses off the filter itself. It's pretty difficult to work on the filter when it's installed. Just a suggestion. :-)
Old Sep 16, 2004 | 05:49 PM
I took the bottom hose off then just pulled the filter up through the engine bay.
Old Sep 16, 2004 | 07:55 PM
Kenteth's Avatar
Like Ghandi with a gun
double clamp the lines, one stocker, one screw clamp. retorque the screw clamp every 6 months
Old Sep 16, 2004 | 08:31 PM
At least somebody agrees with me...
When I got my car, all the fuel lines just had 1 spring clamp on them. That worked fine apparently since, well, I was able to buy the car. So I put those back on and threw on a spring clamp for added peace of mind.
Old Sep 17, 2004 | 05:30 AM
NZConvertible's Avatar
I'm a boost creep...
That only happens if you're silly and overtighten them. I've never had a screw clamp damage a hose.
That's crazy overkill. One screw good clamp is all you ever need, and I've never seen a screw clamp unscrew itself. The stock clamps are okay when first installed but loose tension every time you remove and replace them.
You need to remember that the clamp is not there to hold the hose on by pure friction, it's mainly there to stop the hose being able to expand over the lip at the end of the metal pipe.
Old Sep 17, 2004 | 10:29 AM
I use those and they are great. Won't damage the hose and you can get the size that directly fits your line 3/8" without have problems getting it on or off. Look much better also.
Old Sep 17, 2004 | 10:42 AM
beefhole's Avatar
Cool I'll reuse the spring clamps and put on the screw clamps for good messure.
Old Sep 17, 2004 | 06:39 PM
No, don't reuse the stock clamps. Get new ones.
Old Sep 17, 2004 | 07:02 PM
Better safe than sorry.
Old Sep 17, 2004 | 07:28 PM
Well if you really think that then you'd better go and do the same thing to all 15 connections in the fuel system. Just doing two is pointless.
Old Sep 17, 2004 | 07:37 PM
I did...
I have every fuel hose double clamped.
I have a lot of the air hoses clamped, including the big rubber one coming from the box (thats a big clamp ).
Old Sep 18, 2004 | 08:13 PM
Even the four at the tank?
Jeez you must've been really bored...
What box are you talking about?
Old Sep 20, 2004 | 02:47 AM
I think he is talking about the hose at the back of the intake box going to the airpump.
Old Sep 20, 2004 | 11:23 AM
beefhole's Avatar
Well I have done it, I actually used band clamps. Everything is fine and dandy!
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
sYnth.
Aug 19, 2015 06:27 PM
