Boosting with pump gas?
Old Sep 15, 2004 | 05:32 PM
C Rock999's Avatar
How much boost can I run on my t78 with 91 octane pump gas. I have all the fuel, ignition, porting, etc that is required to run the t78. I've heard 15 lbs. what can you guys tell me.
Thanks,
Chris
Old Sep 15, 2004 | 05:44 PM
RX794's Avatar
NYC's Loudest FD
I've gone as high as 18-19psi on 93 cause that's what super is here on the east coast, don't know about 91 though.
Old Sep 21, 2004 | 06:25 PM
DChan415's Avatar
I've done about 18 psi on 91 octane with no problems running conservative timing and fuel...
Old Sep 21, 2004 | 06:30 PM
spoolin93r1's Avatar
i run 16psi all the time on 92-93
Old Sep 21, 2004 | 06:49 PM
Infini IV's Avatar
Microtech Tuning!
Thanks,
Chris
I see you are located in SoCali where we get the shittiest of gas. How much boost you can run depends on how "conservative" exactly your timing is. Even then, I wouldn't run much over 15psi on our 91oct gas.
Old Sep 21, 2004 | 07:39 PM
C Rock999's Avatar
i wish we could get 100 octane at the stations lol. Does any1 even know how to get 100 octane around the burbank/ san fernando valley area?
Old Sep 22, 2004 | 07:03 AM
Black97VR4's Avatar
FEARED
KDR says I can run 20psi on 93 octane no problem with their anti detonantion device.
Old Sep 22, 2004 | 01:48 PM
Gargamel's Avatar
I run 19psi on the street with my HKS T51R KAI
Old Sep 22, 2004 | 02:35 PM
jeff48's Avatar
Rotorally Challenged
Its all about tuning and fuel delivery capabilities.
Old Sep 22, 2004 | 03:38 PM
Infini IV's Avatar
Microtech Tuning!
You can get 100oct at a 76 station in Pasadena. Something like $5/gallon though.
Old Sep 22, 2004 | 03:59 PM
CCarlisi's Avatar
Rebreaking things
As others have said it really depends on your timing and afrs. I asked both tuners that dialed in my car (on two seperate occasions) where the cutoff is on 93 assuming I want a good safety margin. The first said 15psi is fine with 11.3afr and 13deg of advance around torque peak. The second said 14-15psi with 11.3afr and 14deg of advance.
Old Sep 22, 2004 | 04:25 PM
diyman25's Avatar
RE for life
I run 14 psi. on 91. with 5 gal of 100 . I also premix my gas, 4 oz to full tank
The problem of pump gas. they are not reliable. differnt gas station's gas got different rate. even though they are all rate 91. but they are not the same all the time. you never know the GAS you put in . until It start to knock. on my friend Z06 one time he put a COSCO gas into it. 92 octane. and during high gear up hill drive( the load is big, but speed is not too fast) I heard two pin from the front. and suddenly the car slow down by itself. That is call KNOCK and GM ECU is retard the timing to save the engine . Turbo Rotary dont like this thing. Few pin you Apexi seal will be over and you wont heard the pin like piston do because the Rotary simply too loud to heard by the time you feel it, it could be too later. and plus if you are running PFC good luck. the PFC dont got retard on timing function . so.....
you should be fine under 14 psi I would not boost over it. if you really want to play with boost. got C16
Old Sep 22, 2004 | 04:51 PM
Wargasm's Avatar
Weird Cat Man
I run 15-16 PSI all the time on 93 pump gas with 15 degrees timing around that boost. AFR is 10.8-11.0 according to my Techedge DIY WB.
Brian
Old Sep 22, 2004 | 07:06 PM
Beast From The East's Avatar
Racing is Life.....
And I run 15 psi on 91 with Wargasm's timing map and similar afr's, except I pulled two more degrees of timing to compensate for the less octane gas (so I'm at 13 deg's at peak torque).
Thanks again, 'gasm!
Beast
Rotospectre
Mar 28, 2018 03:33 PM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
CaptainKRM
15
Aug 29, 2015 01:33 PM
smikels
Aug 18, 2015 01:26 PM
