S4 Powersteering on S5
Old Sep 15, 2004 | 07:53 AM
igottafc's Avatar
RX7less **(
i have an S5 FC, the previous owner removed the powersteering, i want ot put it back on, i have the chance to obtain an S4 power steering pump and lines, i already have the PS rack. will the s4 be ok on the S5? The owner beforehand also didnt cap off the inlet/outlet lines on the PS rack. Is there anyway i should clean out the internals before i attach a PS unit? thanks -alex
Old Sep 15, 2004 | 08:12 AM
SureShot's Avatar
Seduced by the DARK SIDE
When you get it all hooked up, flush the system by opening the return line & sitck it in a catch can.
Then keep filling the tank as you turn the steering from side to side.
Maybe run ~2 quarts through it.
Old Sep 15, 2004 | 08:52 AM
Kenteth's Avatar
Like Ghandi with a gun
IIRC the S4 uses mechanical speed sensing, and the S5 uses eletrical speed sensing. Aint gonna work?
Old Sep 15, 2004 | 10:43 PM
igottafc's Avatar
RX7less **(
i didnt think it would. Also i dont know if my car has the PS computer or not since i didnt have the power steering system to reference to for the time i had my car ( it came with the PS removed) is there a certain plug that i can refer to in the engine bay thats for the PS? thanks -alex
Old Sep 16, 2004 | 08:44 AM
igottafc's Avatar
RX7less **(
bump
Old Sep 16, 2004 | 10:45 AM
SureShot's Avatar
The S5 turbo P/S is just like the S4. (electronically controlled)
It's the S5 NA that's different.
Here's a link to the manual click here, then wait while it downloads
Immanuelrx
Dec 25, 2003 11:21 AM
Snook
11
Mar 30, 2003 10:58 AM
