Upper Intake Manifold Nipple Question
Old Sep 15, 2004 | 02:17 AM
marlaman's Avatar
Need an E6x
Question Upper Intake Manifold Nipple Question
Ok I am finishing up the work on my S4 engine into my S5 vert swap along with a manual tranny install also.
So i have a few quick questions that i hope sombody can help me out with.
On the rear end of the passenger side on the UIM there are 2 vac nipples. one is slightly larger than the other, and one is a smaller one at a 90 degree angle.
1. I am thinking a vac hose form the auto tranny once connected to the larger one.--would i be correct?
2.The smaller one at a 90 degree angle--does this connect to the back of the TB where the water thermo sensor is located?
3.I guess i really didn't notice this before but there is a small hose on the side of my oil filler tube. does this connect to anything or is it just a vent?
4.I have searched but i didn't find any definitive answer as to where the vac line is supposed to connect to coming from the cruise control unit. Allthough i did find where the cable went. ha ha ha--that was a joke. Anyway, where is the nipple for that specifically?
5.I switched the water thermo sensor on the back of the TB to a 2 nipple one instead of the 3 nipple that comes with an automatic, the line with the check valve goes to the other side of the TB near the TB fins and if i was wrong on #2 could you let me know where it is supposed to go?
Thanks a lot for answering my questions. it's much appriciated.
Matt
Old Sep 15, 2004 | 09:18 AM
WAYNE88N/A's Avatar
Your cruise control vac line goes to one of the two you were talking about in items #1 & 2, I believe...
Only hose I can think of on the oil breather tube is the purge valve connection...It's not exactly "small", though...
The line from the water thermo switch in #5 goes to the small dashpot thingy for the secondary throttle plates. The vac line on the switch furthest from the TB is the one, with the delay valve in the line...
Old Sep 15, 2004 | 11:29 AM
marlaman's Avatar
Need an E6x
Yep that's what i was thinking
Yep i didn't mean to put small in there, i meant to say short.
Yep that's how i have it. i was tired last night and not thinking straight. So where does the line with the delay valve go?
Old Sep 15, 2004 | 07:07 PM
marlaman's Avatar
Need an E6x
bump.
Old Sep 16, 2004 | 09:45 PM
marlaman's Avatar
Need an E6x
Hey Icemark, would you happen to know where the larger of the nipples on the rear of the passenger side UIM go? This is the only thing i need to figure out before trying to start my car.
Thanks much,
Matt
Old Sep 16, 2004 | 11:06 PM
Icemark's Avatar
Thanks much,
Matt
Normally it is capped off on a S5.
Old Sep 16, 2004 | 11:20 PM
Sir Rupert Hobo's Avatar
seven-less
yup, mine is capped off.
Old Sep 16, 2004 | 11:33 PM
marlaman's Avatar
Need an E6x
Thanks much guys. I'm pretty sure it was connected to the AUTO tranny vac hose after searching the FSM for about an hour just a little while ago. i'm gonna go get my 7 running now. talk to you when she's runnin.
Matt
C. Ludwig
Jan 30, 2019 06:31 AM
86glxNA
Aug 22, 2015 08:54 PM
