Car was smoking in the cabin
Old Sep 14, 2004 | 10:27 AM
MirageJHU's Avatar
My bank acct hates me
Help: smoke in cabin while idling
Ok...this freaked me out, late night drive to Taco Bell for some food, when I got there, got in line in the drive thru, 30 seconds of idling all of a sudden I noticed white smoke coming out of the ac/heater vents and from the shift **** and that stopped like 5 seconds later...I could repeat the smoke to a much greater degree while idling and revving the engine (I tested this in my driveway when I was home so I wouldn't get in trouble) it eventually stops and goes away, but I don't think something like that should be normal..
What is going on?
Old Sep 14, 2004 | 11:26 AM
mazdadude's Avatar
it happens to me for some reason when i push in my ciggarete lighter. smoke comes out of everywhere!!
Old Sep 14, 2004 | 11:30 AM
allforjesus06's Avatar
i love assembly lube
that's called an electrical fire.
Old Sep 14, 2004 | 11:35 AM
YF19's Avatar
i had the white/gray smoke coming from the passenger side foot area. my issue was the previous owner rigged the fan control selonoid and did a wire bypass, which ended up touching and burn a little of my connector.
no wonder i couldn't figure out why i had no fan or max fan and nothing in between.
WAYNE88N/A's Avatar
Is it an electrical smell, or more like an exhaust smell? Big difference there...
Old Sep 14, 2004 | 11:51 AM
igottafc's Avatar
RX7less **(
just put a no smoking sticker in your car, it worked for me
Old Sep 14, 2004 | 01:36 PM
BlaCkPlaGUE's Avatar
I live in an igloo
^what wayne said.
First thing that shot into my mind was that you had a coolanet leak.. as in the overflow tank. When it was trying to fill it back up, maybe it sprayed onto the engine somehow.. lol just a guess.
Old Sep 14, 2004 | 03:43 PM
MirageJHU's Avatar
it just smells like burning things
I'd have to lean towards the exhaust side because I can replicate the smoke by revving and letting off and then waiting
thats really funny with the cig lighter...yeah...
Old Sep 14, 2004 | 04:09 PM
maybe its the heater core going out? Although those usually just blow completely not slowly over time. Also check your shift boot, maybe its both? Id check shift boot since thats kinda easy and also check for like a coolant smell from behind the dash. Hope this helps, good luck.
Old Sep 14, 2004 | 04:24 PM
MirageJHU's Avatar
we just got done messing with the heater core thats all fine, no coolant leaks, I think I need to change all my shifter bushings and that good stuff, but would that cause smoke to come out of the vents like where cold air would come out of??
Also the test for needing new bushings is lots of heat coming outta the shift **** area and the **** moving around a few inches while in gear right...mine's not sloppy like people describe theirs when they need new bushings which is why I am hesitant..or maybe I just don't know what sloppy is haha
Old Sep 14, 2004 | 06:21 PM
Aesop Rock's Avatar
Will Work For Apex Seals
last time i had smoke in that area it was a clogged cat, the cat was on fire under the passenger side foot rest
Old Sep 14, 2004 | 06:23 PM
DerangedHermit's Avatar
That's never good...
Old Sep 15, 2004 | 08:31 AM
MirageJHU's Avatar
I hope its not a clogged cat...it happens when it wants to, it happened again yesterday smells more like exhaust/oil burning
Old Sep 15, 2004 | 08:50 AM
WAYNE88N/A's Avatar
Clooged cat is easy enough to diagnose- how does the car run at high speeds/ rpms?
Does this smoke happen with the blower motor on?
Old Sep 15, 2004 | 09:23 PM
MirageJHU's Avatar
car runs beautifully at high speeds or rpms
if by blower motor you mean AC and such the smoke comes in when its off my AC isn't charged so I don't even use it..
Old Oct 18, 2004 | 03:17 PM
88convert's Avatar
mine does the same thing, but for like 30 seconds on start up... it's weird
Old Oct 18, 2004 | 03:46 PM
Aesop Rock's Avatar
What does it do, msoke in that area.....or smoke out the exhaust?
Old Oct 18, 2004 | 03:49 PM
gaskibba's Avatar
Smile Take a good look underneath
When it starts to do it, take a good look underneath on the passenger side. It sounds like oil and/or coolant getting onto exhaust.
alphawolff
Nov 17, 2015 05:57 PM
gtcd
30
Aug 19, 2015 02:44 AM
pzr2
Aug 15, 2015 08:29 PM
