How do I hook up my a/f gauge
Old Sep 13, 2004 | 07:57 PM
drunkin_idiot's Avatar
Its so hot here!!!!1
OK ,I know, I will get a wideband in the future, but for now this will do. Does anyone have or can they do a write up on how to install an air/fuel guage on my s4 Tii. Including what color wires do what and go where.
Old Sep 13, 2004 | 08:26 PM
Crush's Avatar
Rotorhead for life.
Well, if you got one of the common three wires, the black wire is a ground, so find a part of the frame to put it, the red is power, you can hook it up to any wire that turns on with the ignition, use a test light to find one under the steering column or one used for the stereo. The purple is the signal wire, splice it into your oxygen sensor wire. OR, you can get a wiring diagram for your ECU, and hook all three wires up to their appropiate spots at the ECU.
Old Sep 14, 2004 | 01:22 AM
NZConvertible's Avatar
I'm a boost creep...
Don't connect to the shielded O2 sensor wiring in the engine bay; you have about a 50/50 chance of screwing it up and grounding the whole signal though the wire shield. Always connect at the ECU where the wire is unshielded.
Old Sep 14, 2004 | 01:29 AM
HAILERS's Avatar
HAILERS
That's a dandy jpg of the ECU plugs. Now do the other pins too. humor, please
Old Sep 14, 2004 | 01:45 AM
For more pin info, follow the instructions in my sig...
Old Sep 14, 2004 | 10:48 AM
wow thats super easy, ok now, I dunno where the ecu is located, lol, can someone tell me where it is?
Bauer778
Nov 4, 2015 04:42 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
t-von
Sep 10, 2015 01:56 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
